    Spartan not showing Stryd power anymore.
    6 Posts 4 Posters 279 Views 3 Watching
    • P Offline
      paul870
      Hi, All
      I have not been on here for a while, due to me sticking with Movescount for as long as possible rather than SA, but in December I decided to jump SA fully with my SSS and see what happens.
      Sadly just before, or as I changed my Stryd decided to play up, I thought this may well be due to NOT being fully SA, so this sort of made me more determined to switch to SA.
      I raised a problem with Stryd and as per usual their support has been fabulous with many emails / workarounds / resets etc.
      Finally the Stryd seems to be back to a stable place, phew! running without Stryd seems un-thinkable now.
      PowerCenter is getting all the data from the stryd via offline sync, but I’m no longer getting any power from the SA runs, so they are not getting sent to powercenter.
      BUT my SSS will no longer show any POWER numbers?!
      I have gone back into SA and rebuilt the custom running sport which has power… but still NO joy.
      When I start my run the FOOT POD icon is there and goes GREEN but when I start my run, I just get ‘–’ in the displays?
      Suunto Spartan Sport watch
      Android mobile phone / Suunto app.
      looking for some much needed help on the subject.
      I only just switched to fully SA so I’m struggling to find anyway to see paired devices inside SA but can see them on the watch and everything looks ok.
      SSS
      Ambit3 sport
        I have a Stryd paired as a foot pod with my S9 without issues. But few months ago Stryd (finally) implemented the merge with Suunto files correctly and I had to unpair and then repair SA to Stryd to have everything work.
          Maybe the end of this thread is useful for you also: https://forum.suunto.com/topic/2551/stryd-and-new-suunto-app-are-now-supported/
            A Former User @paul870
            @paul870 have you tried SA beta?
            https://forum.suunto.com/topic/3586/how-to-view-power-data-in-sa/89?_=1610356404778
              reboot the watch.
              "Unpair all devices via connectivity.
              Pair the Stryd ONLY as a footpod.
              If the stryd is paired as both, then 1 of the 2 wont work at all depending on what is found first.
              Oh after pairing dont forget to turn autocalibration off.
              • P Offline
                paul870
                Thanks for all the suggestions, everyone
                Glad to say that it’s all working ok now.
                Seems I was not aware of the changes made to the Stryd / Suunto app process.
                became a show stopper as I have now moved my SSS to SA fully.
                So, deleting all the connections and then remaking them gave the desired result as per Dimitrios’s answer.
                SSS
                Ambit3 sport
