    S9 & Garmin speed&cadence sensor
    16 Posts 8 Posters 1.2k Views 9 Watching
      lemon
      i got a cadence and speed sensor from garmin. How can I pair this with my S9. Since there are two sensors, not just a BikePod.
      Has anyone here already experience?
        Brad_Olwin Moderator @lemon
        @lemon you cannot use both sensors. You need a combined speed/cadence sensor.
        gerbow11G Giacomo LaffranchiniG 2 Replies Last reply Reply Quote 0
        • gerbow11G Offline
          gerbow11 @Brad_Olwin
          @brad_olwin this might help me with a question I have asked. Could I pair in cycling exercise profile a rotor power meter with Suunto 9 Baro and also a combined speed/cadence sensor?
          Thank you in advance.
          Suunto 9 Baro
            Brad_Olwin Moderator @gerbow11
            @gerbow11 yes, that should work fine.
            • 7 Offline
              77alex77 Bronze Member
              Can I use the garmin cadence sensor with my S9 baro ? I don’t need the speed, I need only the cadence. Problem is in S9 manual it is indicated to use the bike sensor pairing and this pairing will ask for a wheel calibration. Can it be an issue if I try to connect the garmin cadence sensor only ?
              I own the suunto bike sensor but I’m not happy with it.
              DMytroD T 2 Replies Last reply Reply Quote 0
                DMytro @77alex77
                @77alex77 I use Garmin cadence sensor on its own just fine.
                7 1 Reply Last reply Reply Quote 1
                • 7 Offline
                  77alex77 Bronze Member @DMytro
                  @dmytro said in S9 & Garmin speed&cadence sensor:
                  Thank you very much, I will order one then.
                    DMytro @77alex77
                    @77alex77 if by chance you’re ordering from Amazon, don’t mind the comments - do not tear off the sticker in the battery compartment, it’s needed to conduct the electricity.
                    • 7 Offline
                      Cadence works fine with the Garmin cadence sensor 2. Thanks.
                        TiagoSPM @77alex77
                        @77alex77 I use garmin Cadence sensor, not with speed, works fine. Sometimes I switch to the speed sensor if I go mountain biking and works fine too. Then back home, switch back to cadence and OK. One at a time!
                        7 1 Reply Last reply Reply Quote 0
                        • 7 Offline
                          77alex77 Bronze Member @TiagoSPM
                          @tiagospm : hello, thank you for the feedback. How do you switch from cadence and speed data ?
                            TiagoSPM @77alex77
                            @77alex77 You have to RESYNC the sensor, pairing each one when you will use it. Like I start to ride my indoor bike with the cadence sensor and it activates, then I go to, in S9, the settings pair sensor and select the bike sensor. Then when I go out with the street bike using the speed sensor I have to start spinning the wheel with the speed sensor so it will activate and then go to the S9 select settings pair sensor again and choose the same bike sensor and override the previous sync doing that. Try it and tell me if it works!
                            • 7 Offline
                              @tiagospm said in S9 & Garmin speed&cadence sensor:
                              Hello and thank you, it is very clear.
                              At the moment, I own only the cadence sensor. When I buy the speed sensor I will try and I’m pretty sure it will work fine.
                              • Giacomo LaffranchiniG Offline
                                Giacomo Laffranchini Bronze Member @Brad_Olwin
                                @brad_olwin Does this apply to the S9P as well.
                                I just ordered the bundle Garmin cadence 2 and Speed sensor 2. As I understand I will only be able to use either the cadence OR the speed but not both concurrently?
                                Thanks in advance
                                S9P Granite Blue Titanium
                                • BulkanB Offline
                                  Bulkan Moderator @Giacomo Laffranchini
                                  @giacomo-laffranchini Yes only one, the broadcasts of the signal is 1:1 so in if in this 1 is not cadence and speed you only get one.
                                  Giacomo LaffranchiniG 1 Reply Last reply Reply Quote 0
                                    Giacomo Laffranchini Bronze Member @Bulkan
                                    @bulkan Got it, thank you for the clarification.
                                    When I ordered the sensors I guess I misinterpreted the meaning of 1 sensor per type.
