    Smart sensor belt fault
    4 Posts 4 Posters 356 Views 3 Watching
    • aksta70A Offline
      aksta70
      Smart sensor belt does not seem to pick up correct heart rate or sometimes nothing at all. Belt is about a year old. Is there a shelf life for these? The belt has been washed, I wet the patches before use and new battery in the sensor itself but still not working
      aroo7A surfboomerangS ? 3 Replies Last reply Reply Quote 0
      • aroo7A Offline
        aroo7 Bronze Member @aksta70
        @aksta70 Probably you need replace the battery in sensor. Sensors using bluetooth for communication are definitely more energy-consuming than ant+
          surfboomerang @aksta70
          @aksta70 I think you did everything possible. I noticed some belt work better if you wet the patches with salt water or conductive gel
          Sounds to me like a broken belt. It shouldn’t happen after a year but isn’t impossible.
          Do you roll up or bend the belt sometimes to storage it?
            A Former User @aksta70
            @aksta70 said in Smart sensor belt fault:
            It is the one with movesense area in black or grey?
