    Problems with sport mode after update to 2.14.12
    25 Posts 9 Posters 5.9k Views 9 Watching
    • Olli2709O
      Olli2709 Bronze Member
      Hi together. Yesterday i made the update for my Suunto 2.14.12 . This was interrupted an so i have to reset the watch and start again. The new software was then installed, but I cannot now call up or change any sport modes in the app. “Loading list” is displayed permanently and nothing changes. I installed the Suunto app on 2 iphones and both have the same problem! Does anyone else have this issue or know help?suunto.PNG
      Watsches: Ambit 3, Ambit 3 Vertical, Suunto 5
      Currently testing: Vertical Solar & Core 2 :-)
      T Olli2709O 2 Replies Last reply
      Reply Quote 0
      • T
        tarzan @Olli2709
        @olli2709 I have the same problem. I have restarted my iPhone, restarted my watch, and deleted and reinstalled the Suunto app. Nothing has solved the problem
        1 Reply Last reply
        Reply Quote 0
        • Olli2709O
          Olli2709 Bronze Member @Olli2709
          @tarzan Did you do the hard reset? You have to connect the watch to the PC with the cable and reset the watch via Suunto link. A reset via the clock (press the buttons for 12 seconds) is not sufficient. That worked for me.
          T 1 Reply Last reply
          Reply Quote 0
          • Dimitrios KanellopoulosD
            The issue is understood. For now the advice is to full reset the watch
            Creator of quantified-self.io
            1 Reply Last reply
            Reply Quote 0
            • T
              tarzan @Olli2709
              @olli2709 If I do the hard reset, will have to recreate the custom sports modes that I am currently using? or are they stored in Suunto App?
              Brad_OlwinB 1 Reply Last reply
              Reply Quote 0
              • Brad_OlwinB
                Brad_Olwin Moderator @tarzan
                @tarzan said in Problems with sport mode after update to 2.14.12:
                They are not stored! I take screenshots and save them so I can reproduce my custom sport modes.
                Vector/T6c/Vertical 2 Ti
                Reply Quote 0
                • B
                  Bradleyd Bronze Member @Brad_Olwin
                  @brad_olwin and @Dimitrios-Kanellopoulos, if we choose not to hard reset, is there any (known) downside other than unchangeable sports modes?
                  Looking forward, is there any expectation that the guidance will change and a full reset will be unnecessary?
                  1 Reply Last reply
                  Reply Quote 0
                  • isaziI
                    Update to 2.14.14 should be available now.
                    Blog: isazi’s home
                    herlasH T S 3 Replies Last reply
                    Reply Quote 0
                    • herlasH
                      herlas Silver Members @isazi
                      @isazi S5 only?
                      SR3S
                      isaziI 1 Reply Last reply
                      Reply Quote 0
                      • isaziI
                        isazi Moderator @herlas
                        @herlas it’s an S5 specific fix for the issue described in this topic.
                        Blog: isazi’s home
                        S 1 Reply Last reply
                        Reply Quote 2
                        • T
                          tarzan @isazi
                          @isazi The 2.14.14 update did not solve my problem. I did a soft reset and deleted and reinstall the Suunto app. I have been resisting the hard reset because I don’t want to risk losing existing custom sports mode if for some reason the hard reset did not solve problem.
                          Olli2709O isaziI 2 Replies Last reply
                          Reply Quote 0
                          • Olli2709O
                            Olli2709 Bronze Member @tarzan
                            @tarzan For me, only the hard reset solved the problem. It’s annoying, but in about 2 hours of work I re-created all of my personal sport modes.
                            1 Reply Last reply
                            Reply Quote 0
                            • isaziI
                              isazi Moderator @tarzan
                              @tarzan I asked if the update is enough or a reset is necessary.
                              Blog: isazi’s home
                              Brad_OlwinB isaziI 2 Replies Last reply
                              Reply Quote 0
                              • Brad_OlwinB
                                Brad_Olwin Moderator @isazi
                                @isazi I had to do a hard reset to get everything working again for my S5.
                                1 Reply Last reply
                                Reply Quote 0
                                • S
                                  SamLondon @isazi
                                  This post is deleted!
                                  1 Reply Last reply
                                  Reply Quote 0
                                  • S
                                    SamLondon @isazi
                                    @isazi said in Problems with sport mode after update to 2.14.12:
                                    sorry just re-reading, can you delete previous pls
                                    1 Reply Last reply
                                    Reply Quote 1
                                    • isaziI
                                      isazi Moderator @isazi
                                      @tarzan I asked, you are supposed to do a hard reset with 2.14.14 and the problem should not happen again, but yeah you need this reset because the corruption already happened.
                                      For people that not had the issue manifest itself, just update to 2.14.14 and you will not need to do a hard reset.
                                      Blog: isazi’s home
                                      Olli2709O T 2 Replies Last reply
                                      Reply Quote 3
                                      • Olli2709O
                                        Olli2709 Bronze Member @isazi
                                        @isazi The problem is that with every software update of the watch the update is interrupted, I have to reconnect the watch and then an automatic hard reset takes place, so that all sport modes are gone !!! This was the case with the last two updates of my suunto 5. Very annoying. I’ll skip the next update if it’s not important. It must be possible, similar to an iphone, to save the watch’s settings and reload them.
                                        isaziI Łukasz SzmigielŁ 2 Replies Last reply
                                        Reply Quote 0
                                        • isaziI
                                          isazi Moderator @Olli2709
                                          @olli2709 unfortunately what you experience should not happen, meaning that updates should not get interrupted and force a hard reset. Something must be wrong with your cable or computer.
                                          Blog: isazi’s home
                                          Olli2709O 1 Reply Last reply
                                          Reply Quote 1
                                          • Łukasz SzmigielŁ
                                            Łukasz Szmigiel @Olli2709
                                            @olli2709 this isn’t normal. I never had to hard reset my S5 since I bought it and all updates went well first day they went online.
                                            S9PP 2.50.28
                                            1 Reply Last reply
                                            Reply Quote 0
