    V02max problems
    8 Posts 3 Posters 445 Views 3 Watching
    • P Offline
      Phipsl
      Hy guys,
      Yesterday I trained in my aerob fitness level. I ran for 90minutes.
      I was excited about my V02max( i had a few runs before with max.40minutes- always with v02 data) but sadly the app didnt show it to me.
      Can anybody tell me why? Was the run too long? Is it a bug? Gps and heart rate were always on and i have alle the Data…except V02max
      Thx in advance,
      Philipp
        DMytro @Phipsl
        @phipsl there is also a dedicated page for v02max in SA, does it show smth there for the day you did your run? Can you also check logbook in the watch for v02max value?
        There are no duration restrictions for v02max value. However it’s dependent on your sports mode: if it’s a custom one which isn’t build upon walking, hiking, running - you may not get v02max estimate.
        • P Offline
          Phipsl @DMytro
          @дима-мельниченко thanks for your answere.
          No, it doesnt matter where I look, there is no V02max. I can find it in all the other sports mode in the App or on the watch. I know that I need to start a mode which is similar to running or hiking.
          The only difference was that I have chosen a heart rate Zone in running mode. Zone 3 for an aerobe training🤷🏻‍♂️
            DMytro @Phipsl
            @phipsl this shouldn’t deactivate v02max. Maybe one time bug? Would be nice if you could try the exact same setting again to confirm whether it happens again.
            P 2 Replies Last reply Reply Quote 0
            • P Offline
              Phipsl @DMytro
              @дима-мельниченко ok thanks. I will reply than here
              • P Offline
                Phipsl @DMytro
                @дима-мельниченко Okay i ran for an hour today and I saw the V02max then. As you said, maybe an one time bug🤷🏻‍♂️
                  DMytro @Phipsl
                  @phipsl perfect! Keep us updated if that happens again - I never had this issue.
                    I had the issue and reported it to Suunto.
