    Incorrect distance when hiking
    35 Posts 7 Posters 3.0k Views 7 Watching
      Dimitrios Kanellopoulos Community Manager @Tomas5
      @tomas5 in theory were the reception is ok , those problems (gps erratic data etc) should not happen.
      The best you can do also data wise is to pause when the pause is something more than 5-10mins.
      Tomas5T 1 Reply Last reply Reply Quote 2
      • Tomas5T Offline
        Tomas5 @Dimitrios Kanellopoulos
        So with glonass it is not better at all. Today 7.9km route was measured as 9.23km and now i manually paused every break. I must say that compared to Ambit 2s i am very disappointed. I preferred suunto brand but i must say these are my last suunto watch ever. Again everyone with average mobile phone cheaper than this watch recorded more accurate gps track.
        • Łukasz SzmigielŁ Offline
          Łukasz Szmigiel @Tomas5
          @tomas5 are you sure your watch is up to date and AGPS is fresh? I’m getting pretty awesome results with Galileo with latest firmware almost always, regardless of terrain. My last hike was in the forest, around some rocks etc and the track is very good. You will get some extra distance due to GPS inconsistency compared to official track measurements but 7 vs 9 km is a bit too much.
          S9PP 2.40.44
          • Tomas5T Offline
            Tomas5 @Łukasz Szmigiel
            @łukasz-szmigiel i synced watch before hiking and firmware is up to date. Version 2.14.16. And here on forum 3 days ago some another user complained about gps measuring more than real distance too which is same issue i think. I will try next time with Galileo than. But i am loosing my hopes that this watch will perform as good as my old Ambit 2s.
            • Tomas5T Offline
              Tomas5 @Tomas5
              there is not much problem on open area on meadow etc. accuracy is good enough. But while hiking in hills where are trees there is really bad accuracy.
                @tomas5 have you tried other systems too? Beidou or GPS only? Same results? How do you know the distance is off? Is it off compared to different device (ie. smartphone) or official trail?
                S9PP 2.40.44
                • Tomas5T Offline
                  @łukasz-szmigiel i tried gps only and gps + glonass. I did multiple hikes it is always more than official distance by multiple map services and it is more than my father or my wifes phone measure too. Phones are usually much more close to official route distance than suunto 5. When i opened this thread there was issue i didn’t pause while break so i was able to accept that watch measured some distance while 20min break. But now for every break i manualy paused. But still it was off. And it can be seen on map that it jumps around route instead of strait line like it supose to be.Snímka obrazovky 2021-06-05 o 13.49.40.png
                  • Tomas5T Offline
                    Tomas5
                    And i must say that i don’t have this problem while on bike. Measuring is quite correct but i use bikepod so maybe distance is corrected by bikepod which i have calibrated quite well. I believe that with 10s fix it would be more accurate since it would be more streight but there is no such possibility and i will loose ascent and descent with 60s gps fix (endurance). So this is not a good way to fix accuracy. If snap to route would be backported from new suunto 9 to older watch it could fix this great.
                    • Tomas5T Offline
                      Tomas5 @Tomas5
                      @tomas5 one of my friend just told me that with suunto 9 he had problems too but combination GPS + galileo improved accuracy a lot. I will return to this post in few weeks with results. Hope it will improve it.
                        @tomas5 if you’re doing slow hikes you won’t loose much of ascent / descent with “good” gps mode I think. Considering that gps is poor for vertical measurements anyway (especially if signal is bad).
                        You may also want to try “good” gps mode and switch to navigation screen in order to trigger “best” mode for as long as long you’re on the navigation screen (as a workaround or when actually navigating).
                        S9PP 2.40.44
                        EgikaE Tomas5T 2 Replies Last reply Reply Quote 2
                          Egika Platinum Member @Łukasz Szmigiel
                          @łukasz-szmigiel afaik in good GPS mode there is no altitude measurement at all in the S5…
                          Run Lime
                            Łukasz Szmigiel @Egika
                            @egika oh now I see - the altitude is being reported for each fix but not ascent / descent. Thanks for making it clear.
                            S9PP 2.40.44
                            • Tomas5T Offline
                              @łukasz-szmigiel thanks didn’t know it can be changed with navigation to better precisision. And good means 60seconds fix right? 10s fix was best for hiking with ambit but it was at cost of loosing ascent descent data. But withou baro it is not so accurate so not so important too.
                                @tomas5 good is 1 min fix, best is 1s fix. However as @Egika pointed out - you’ll loose ascent / descent with anything else than best.
                                S9PP 2.40.44
                                • Tomas5T Offline
                                  @łukasz-szmigiel gps + galileo looks best. With manual pause. I did exactly same hike today as few months ago. Now distance is correct and accuracy quite good. I see zig-zag on route but it is not much and didn’t increase distance so it is ok. And even elevation and ascend descent was correct. I must say after some time i am happy with result.
                                  Edited: i use gps + galileo 🙂
