    GPS problem with latest update in Fused Track mode
    17 Posts 6 Posters 1.1k Views 6 Watching
      tonyg42
      Yesterday I made a mountain biking trip in Fused Track mode, and trace is completely crazy. As you can see on screenshot, GPX track turns around real path… I never had this problem before latest update. Has someone already seen this behaviour?
      Thank you!
        Egika Platinum Member
        Yes, I have had this on a bike ride right after the first time Fused Track became available on the S7 last September.
        Feedback from the devs was that the sensors did not manage to get calibrated party because when riding a bike the watch is not rotating around all axes. It should get better after some minutes.
        For me it stopped where I switched from good to best GPS and back to good at a crossroad.
        And since then I’ve never had it again.
          tonyg42
          Thank you Egika. For me it was the opposite : track was OK during first 2 hours, and suddenly it becomes very bad until the end. I think that I will also switch back to best GPS mode… I’m a little bit disappointed because FusedTrack was better for energy consumption (less than 20% in around 3 hours of ride). That’s the first time that I have this issue.
          EgikaE Brad_OlwinB 2 Replies Last reply Reply Quote 0
            Egika Platinum Member @tonyg42
            @tonyg42 thats interesting. Could you identify anything at the point where it started wobbling? Maybe a high voltage power line, or a break or some other magnetic interference from equipment etc?
              tonyg42 @Egika
              @egika No, nothing special from the magnetic point of view. But that was after a long time (about 20 minutes) of pushing my bike (on foot) up a long steep climb.
                sartoric Moderator @tonyg42
                @tonyg42
                Was your watch near some magnet or electronic device while you were pushing ?
                We’ve seen issues long time ago with gloves with magnetic fasteners 😁
                Suunto App Android 6.3.3 beta
                  tonyg42 @sartoric
                  @sartoric No, no electronic device nor magnet was near my watch. Only thing is that my arm was horizontal during a long time perhaps ? My phone is always in my backpack.
                    Brad_Olwin Moderator @tonyg42
                    @tonyg42 Unless you are out for more than 25h there is really no reason to use FusedTrack. Furthermore, FusedTrack is not designed for biking as the sensors work much better when your arms are moving. FusedTrack is primarily for running and hiking. I have engaged FusedTrack for SkiMo, it is fine on the uphills but as expected poor on the downhills.
                    giulioG T 2 Replies Last reply Reply Quote 0
                    • giulioG Offline
                      giulio @Brad_Olwin
                      @brad_olwin
                      Excuse me but for my opinion Fusedtrack for hiking is very poor,inusable to follow a track
                        tonyg42 @Brad_Olwin
                        @brad_olwin sorry but I need sometimes 10 hours for biking and without FusedTrack, it is difficult. FusedTrack is foreseen for biking and running in Suunto presentation. And until now, it was ok.
                          @tonyg42 Sorry, thought you were using a Suunto 9. I am wrong and you are correct. It should work better for biking. I use FusedTrack on the 7 often.
                            Brad_Olwin Moderator @giulio
                            @giulio would you like me to post? I have many good tracks while moving slowly and good ones for uphill SkiMo
                            giulioG 1 Reply Last reply Reply Quote 0
                            • giulioG Offline
                              giulio @Brad_Olwin
                              @brad_olwin
                                tonyg42 @Brad_Olwin
                                @brad_olwin I checked my old biking GPX and I never had this problem before. I hope it will not reproduce too often. Let’s see during next trip. 😉
                                  FusedTrack should work with biking on the s7. I have seen that pattern again and its usually due to some compass not being calibrated or some heavy metal at the bike mount
                                    tonyg42 @Dimitrios Kanellopoulos
                                    @dimitrios-kanellopoulos Thank you. How to calibrate compass please ?
                                      Dimitrios Kanellopoulos Community Manager @tonyg42
                                      @tonyg42 do the figure 8 gesture .
