    Suunto Plus - bug when selecting suunto plus
    16 Posts 7 Posters 1.8k Views 7 Watching
    • Tomas5T Offline
      Tomas5 Gold Members
      Hello, i found out little bug today. When starting exercise i can go to options and in SuuntoPlus i can browse all possible suunto plus screens. When i am on some suunto plus screen and press button back (left bottom button), suunto plus get selected in same way as i would press middle right button to select this screen. I would expect that when i press back button, it will not select suunto plus screen and it will stay on previously selected option.
      isaziI surfboomerangS 2 Replies Last reply Reply Quote 1
      • isaziI Online
        isazi Moderator @Tomas5
        @tomas5 I’ll check if I can reproduce this
        • surfboomerangS Online
          surfboomerang @Tomas5
          @tomas5 This is normal behaviour. I noticed this also on other settings like GNSS combinations. I have to admit it is a little bit counter-intuitive
          • Łukasz SzmigielŁ Offline
            Łukasz Szmigiel @surfboomerang
            @surfboomerang hm but it doesn’t work like that everywhere I think? Ie. when setting custom battery modes there’s no way to back-accept it, you have to accept it with top or middle I think?
            S9PP 2.50.28
            Tomas5T surfboomerangS 2 Replies Last reply Reply Quote 1
            • Tomas5T Offline
              Tomas5 Gold Members @Łukasz Szmigiel
              @łukasz-szmigiel back button works as expected on Battery Mode, but doesn’t work on Suunto Plus, Theme and maybe others too.
              In this two example back button works same way as accept button. It is strange and not intuitive behavior.
              From programmers point of view it looks like some settings change inner variable while browsing list of options and other settings change inner variable when accept button is pressed.
              • isaziI Online
                I asked if this is intended or not. Not sure I’ll get an answer, but I will report if I do.
                  Łukasz Szmigiel @Tomas5
                  @tomas5 I wonder how it’s done in S9 where there’s no back button but swipe only?
                  S9PP 2.50.28
                  surfboomerangS D 2 Replies Last reply Reply Quote 0
                    surfboomerang @Łukasz Szmigiel
                    @łukasz-szmigiel True, but for settings within “custom battery mode” it does work. Try GPS setting for example
                      @łukasz-szmigiel Long press middle button is the back button
                      • isaziI Online
                        So this is known, and expected to work this way.
                          DF130 Bronze Member @Łukasz Szmigiel
                          @łukasz-szmigiel I think there is some inconsistency with the S9 as well. A little triangle at the rhs usually means one can swipe or press the middle button (eg when going through the sports modes), but when in the Suunto+ menu one can only press the right button (which then returns) or swipe in the other direction to activate one‘s choice of Suunto+, despite the little triangle being shown. Not a big deal for me but I noticed recently (mainly using Ghost)…
                          • herlasH Offline
                            herlas Silver Members
                            on my S9P scrolling through the list of S+ options and doing a swipe left on the screen, will leave that option as selected, not sure if we want that, also not sure if that was the behavior on S9B 🙂
                            SRS Ti
                            • Tomas5T Offline
                              Tomas5 Gold Members @isazi
                              @isazi sound like programmers wanted to make their job easier 😄
                                Dimitrios Kanellopoulos Community Manager @Tomas5
                                @tomas5 or UX. Else it would be a bug.
                                Devs only do what UX instructs.
                                So PO - makes feature
                                UX - decides how it works
                                Dev be like : Ooookey
                                Tomas5T 1 Reply Last reply Reply Quote 3
                                • Tomas5T Offline
                                  Tomas5 Gold Members @Dimitrios Kanellopoulos
                                  @dimitrios-kanellopoulos agree 😉
                                    @tomas5 it has been discussed and my self I do find it not expected as of behavior. Forward should confirm and back should cancel without applying.
                                    But the case is that if you notice that this is inconsistent in the watch ecosystem.
                                    Sometimes it works as expected and some options like you mention doesn’t .
                                    I pass this and raise it once more to the UX and team.
