    S9 power meter compatibility
    3 Posts 2 Posters 482 Views 2 Watching
      lobo_tommy
      Hello
      Is there a list of S9 compatible power meters? Does anyone know if 4iiii Precision is compatible, or should I assume that all bluetooth power meters will work with the watch? What is your experience in the cooperation between the two. I already have the Suunto cadence/speed sensor attached.
      I would appreciate your input. Thank you in advance.
        isazi Moderator @lobo_tommy
        @lobo_tommy all bluetooth power meters should work, but remember that if you have a power meter (i.e. a pedal based one) that transmits data over two channels you cannot pair both. The 4iiii precision seems crank based so should be fine.
          lobo_tommy @isazi
          @isazi thank you. Correct, 4iiii is a single crank sensor.
