    Di2 for Suunto 9
    3 Posts 2 Posters 523 Views 2 Watching
    • TimoKT Offline
      TimoK
      When Suunto 9 will be compatible with Shimano Di2? Would be great to be able to switch between displays during exercise. In addition the gear indicator can be added to training fields
      S9b
      • BulkanB Offline
        Bulkan Moderator
        I’m not in the electric change of Shimano. Can you explain more what do you want and the worth of it?
        As far as I know you can switch the gear and the fit file records the gear you are in. But I don’t know if it has more practical cases.
        TimoKT 1 Reply Last reply Reply Quote 0
        • TimoKT Offline
          TimoK @Bulkan
          @Bulkan
          It´s mainly for getting information out of Di2 gear system like the battery status and information about actual gear combination in front and back gears which biker is using.
          In addition the BT connection makes possible to use Di2 buttons in levers to switch between different displays in Suunto watch during exercise. You can keep your hands on the levers and i.e. change between navigation display and basic display.
          S9b
