    S5 2.18.18 crash during workout / no vertical navigation prior
    14 Posts 6 Posters 1.2k Views 5 Watching
    • Łukasz SzmigielŁ Offline
      Łukasz Szmigiel
      I had a watch crash into charging screen today. The only thing that was uncommon during the hike was vertical navigation (route altitude) missing from its screen. I also had S+ Burner loaded and multimedia controls were on (although there was no multimedia so it was standby).
      The crash occurred when I wanted to change navigation to “find back”. The screen went black and then charging icon appeared. The watch was at around 30% charge during that time (I’ve started with 41%).
      After plugging in the watch to my PC it booted up ok and continues to charge from 30%. It also did an activity sync up to a point when the watch died, although with no ascent / descent available. Also lowest / highest points make no sense (26m / 60m). There’s also some data missing but I suspect this is due to the workout not being saved properly.
      I’ve sent logs to Suunto with ID: 886205577179900
      Is there anything else I can do to help debug this issue?
      S9PP 2.44.52
      Dimitrios KanellopoulosD Ivan De RasisI 2 Replies Last reply Reply Quote 2
        Dimitrios Kanellopoulos Community Manager @Łukasz Szmigiel
        @łukasz-szmigiel thank you for the logs ! I’ll update you next week.
          Łukasz Szmigiel @Dimitrios Kanellopoulos
          @dimitrios-kanellopoulos anything new about this one?
          S9PP 2.44.52
            Brad_Olwin Moderator @Łukasz Szmigiel
            @łukasz-szmigiel I will try to test this as well, you had burner running and media controls on as well as a route loaded?
              Łukasz Szmigiel @Brad_Olwin
              @brad_olwin yes, and galileo - which may also be important as I believe the interface is somewhat slower when using this GNSS. But this may be as well placebo.
              I was unable to reproduce it so far.
              S9PP 2.44.52
              • Ivan De RasisI Offline
                Ivan De Rasis @Łukasz Szmigiel
                @łukasz-szmigiel Anch’io ho riscontrato gli stessi problemi e deduco siano dovuti all’ultimo aggiornamento eseguito
                Suunto 9 Baro
                Ivan De RasisI 1 Reply Last reply Reply Quote 1
                  Ivan De Rasis @Ivan De Rasis
                  @ivan-de-rasis anche perchè il mio Suunto 9 Baro, fino all’ultimo aggiornamento, è sempre andato una scheggia!!!
                  Suunto 9 Baro
                  • inkognitoI Offline
                    inkognito Platinum Member
                    @Brad_Olwin @Łukasz-Szmigiel @Dimitrios-Kanellopoulos
                    I encountered the same with S9 non-baro. I used GPS+Beidou, S+ Burner and media controls. My watch didn’t crash. When I tried to choose different route, the issue remained the same. Sometimes when I was switching between screens, the altitude navigation chart appeared for approximately one second (and looked somehow strange) and then it disappeared.
                    SV: fingers crossed :D
                      Łukasz Szmigiel @inkognito
                      @inkognito in my case the crash happened when I wanted to switch from navigation to find back. Generally the interface freezes for a moment whenever I do so but this time it froze and then died.
                      S9PP 2.44.52
                      Ivan De RasisI 1 Reply Last reply Reply Quote 0
                        @łukasz-szmigiel Ho provato per tre volte consecutive ad accedere al menù Ritorna alla partenza e tutte le volte il mio S9B si è resettato da solo
                        Suunto 9 Baro
                          Łukasz Szmigiel
                          The crash happened again today - same hiking profile, different route, same other settings.
                          Logs from right after the watch booted up after connecting to PC:
                          1229920506550300
                          I was anticipating it as there was no vertical navigation and the watch took like 5 seconds to start after pressing the middle button. So when I was approaching the end of my route, I recorded the video:
                          https://photos.app.goo.gl/maUgWAAk48ZxAcJr7
                          You can see that the watch crashes when switching from route navigation to find back.
                          My settings:
                          1. Screens (hiking):
                          As you can see - there’s plenty of data but I like it this way when I’m hiking. I’m moving slowly so I can switch between the screens when needed. Perhaps it’s crashing because there’s too much to process?
                          2. Watch settings
                          • HR 24/7 enabled
                          • Sleep tracking enabled
                          • Media controls enabled (no music was available during the navigation)
                          • Beep disabled
                          • Vibration enabled
                          • GPS + GLONASS (it was Galileo last time)
                          • Sun ring watch face
                          3. Workout settings
                          • Performance
                          • ~47% battery in the beginning
                          • Polar H10 connected
                          • S+ Burner enabled
                          • Route loaded
                          4. May be important or not
                          • Both last time and today I’ve created the route on location in my car with no internet connectivity - I know it shouldn’t matter as watch <-> SA sync is offline but those are the similarities I remember.
                          • In no more than 5 minutes after the start I already had ascent of ~80m (last time and today) which hardly ever happens with GLONASS - especially if I wait for a while before hitting the start. I don’t remember seeing such discrepancy when the bug doesn’t occur.
                          S9PP 2.44.52
                          isaziI 2 Replies Last reply Reply Quote 1
                            @łukasz-szmigiel thanks for the logs, I am reporting it.
                              @łukasz-szmigiel well, cannot say much about this but devs may be fixing this, your detailed report was very useful.
                                Łukasz Szmigiel @isazi
                                @isazi thank you. I’m happy that the report was useful! I’ll try the same settings next time without Burner and/or media controls.
                                S9PP 2.44.52
                                • Łukasz SzmigielŁ Łukasz Szmigiel referenced this topic on
