    Full battery drain in around one hour
    5 Posts 5 Posters 363 Views 5 Watching
    • fazelF Offline
      fazel Bronze Member
      I searched and didn’t see anyone having this issue. I’ve not used my watch for several months as I have just been cycling but took it off the charger yesterday and the battery drained over the course of several hours. I restarted the watch and quit the app on my phone.
      When I got home I charged it then installed the new firmware through Suuntolink. I assumed this might have been the issue but it does not appear to be the case. I put it on this morning and it drained even quicker. After recharging, I disconnected from the app and forgot the connection in the iOS bluetooth settings and then reconnected. However, I’m already down to 81% after only around 30 min off the charger.
      Any ideas?
      DMytroD Daniele GusminiD 2 Replies Last reply Reply Quote 0
        DMytro @fazel
        @fazel maybe soft-/hardreset?
        • MiniForkliftM Offline
          MiniForklift Platinum Member
          I’ve had a few S9B’s with battery drain issues, I just returned them to Suunto here in New Zealand. In each case they came back to me and said that yes, there’s an issue but no it is not fixable. I have got a replacement each of these times
          My training partner also went through 3 S9B’s with battery issues, so I’m inclined to almost think that there may be a batch out there that all suffer from the same integral problem(s). I got lucky I think with my third S9B which I have had for around 18 months now
          So in short I’d see if you can take it into or send it away to your closest Suunto dealer. Keep us posted
          SV Titanium Solar Forest
          • Daniele GusminiD Offline
            Daniele Gusmini @fazel
            @fazel I have a similar problem. After the latest firmware update (2.18.20) the battery drains 2% per hour. Already tried soft and hard reset without success
            reneulmerR 1 Reply Last reply Reply Quote 0
            • reneulmerR Offline
              reneulmer @Daniele Gusmini
              @daniele-gusmini Same to me. Battery has become noticeably much worse! Seems like a software issue, any feedbacks from Suunto? How to proceed?
