    GPS problem
    6 Posts 4 Posters 1.0k Views 4 Watching
    • Y Offline
      ylwendy
      I’ve done settings on navigation n there is no issue in locating my current location… However when I started my activities like walking or hiking, there is no gps found. What should I do?
        Brad_Olwin Moderator @ylwendy
        @ylwendy check AGPS in about menu. Is there a file present and is the file current?
        • Catoer WibowoC Offline
          Catoer Wibowo
          hi all, i have problem with GPS today. the day is bright, sky is clear, power saving is off, but the watch could not lock even after i ignore and start running. i dont know why this happened. please let me know what to do or check?
          Suunto Spartan Trainer Wrist HR (traded in with S5)
          Suunto 5
            freeheeler @Catoer Wibowo
            @catoer-wibowo
            I assume you checked the AGPS file according to Brad’s suggestion?
            It helps when this is relatively up to date, afair not older than 5 days (!?)…
            my impression is: ignoring and start running makes it even harder for the watch to lock satellites, when it already struggles… but I could be wrong
              @freeheeler said in GPS problem:
              @catoer-wibowo
              You are correct, without a lock it can take a long time to get the GPS fix while running…tested that.
                Catoer Wibowo
                thank you all, i finally restarted the watch by pressing the two upper buttons for about 12 seconds. the watch restarted and after that, the GPS works perfectly and I feel that it is even a bit more accurate i.e. from cold start when you are doing the workout. anyway, thanks for the suggestions. cheers
                Suunto 5
