    bike sensor and cadence
    16 Posts 7 Posters 1.7k Views 7 Watching
    • Krzysztof BorkowskiK Offline
      Krzysztof Borkowski
      Sorry if such question has already been asked.
      For some reason my bike sensor stopped showing cadence (during ride and in summary charts). What am I doing wrong?
        Brad_Olwin Moderator @Krzysztof Borkowski
        @krzysztof-borkowski what watch and what sensor? Suunto requires a combined speed and cadence sensor.
        Krzysztof BorkowskiK 1 Reply Last reply Reply Quote 0
          Krzysztof Borkowski @Brad_Olwin
          @brad_olwin sorry, thought that is in topic i can talk only about Suunto 9. I gotta Baro version. And sensor is called just Bike Sensor.
          “SS022477000
          SUUNTO BIKE SENSOR
          Measure speed, distance and cadence on your rides”
          https://www.suunto.com/en-gb/Products/PODs/Suunto-Bike-Sensor/
          And this combination for sure was working. I guess 🙂
            @krzysztof-borkowski other that the obvious, magnets, etc., perhaps the sensor is broken. Did you try a soft reset of the watch?
              @brad_olwin Do you have an idea how to verify it without buying a new sensor? It seems to me that all other indications, in all sports, are okay. The only problem is cadence.
              Yes, I even did a hard reset and reinstall the sensor.
              MdzOttM 1 Reply Last reply Reply Quote 0
              • MdzOttM Offline
                MdzOtt @Krzysztof Borkowski
                @krzysztof-borkowski is this a new sensor or has it worked before?
                R2
                S9 Baro
                SA on Android
                Ambit 3 Peak
                Ambit 2 Sapphire
                  Krzysztof Borkowski @MdzOtt
                  @mdzott i guess i have it for few years (more than 2). And as i said, every other indications are okey. the only problem is cadence. I wonder if it could be a mechanical damage, some kind of shift or something or the problem is in the software. Is there any way that I ticked it off or something?
                  L Brad_OlwinB 2 Replies Last reply Reply Quote 0
                    Likarnik Gold Members @Krzysztof Borkowski
                    @krzysztof-borkowski did you try with new battery in sensor? I had similar problems and battery change solved them. CR2032 if I’m not mistaken, cheaper than new sensor 🙂
                      @krzysztof-borkowski I seriously doubt it is the watch, most likely the sensor. You could contact support.
                        @brad_olwin @Likarnik Thx guys for your energy. Yes, battery was changed. The problem was/is with magnet. I took one from my wifes bike 😉
                        Still, during ride I have no visualization of current cadence.
                        Ars VitaeA 1 Reply Last reply Reply Quote 0
                        • Ars VitaeA Offline
                          Ars Vitae Silver Members @Krzysztof Borkowski
                          @Krzysztof-Borkowski Can I ask you, where in exercise menu on the watch the actual cadence should be displayed while cycling? Is there any Suunto App for it?
                          Mads Hintz-MadsenM 1 Reply Last reply Reply Quote 0
                          • Mads Hintz-MadsenM Offline
                            Mads Hintz-Madsen @Ars Vitae
                            @Ars-Vitae said in bike sensor and cadence:
                            You can configure that yourself in the Suunto App. Below you can see an example of how I have customized this for the Indoor Cycling profile.
                            Ars VitaeA 1 Reply Last reply Reply Quote 1
                              Ars Vitae Silver Members @Mads Hintz-Madsen
                              @Mads-Hintz-Madsen Thanks for your help. So basically there is no app or menu in cycling exercises dedicated to this parameter, I have to create it by myself. A little strange considering the existence of a dedicated Suunto bike sensor.
                              L AudaxjoeA 2 Replies Last reply Reply Quote 0
                                Likarnik Gold Members @Ars Vitae
                                @Ars-Vitae there was a couple of years ago, that had cadence as data field (cycling - cadence, like currently you have cycling - power), but disappeared with FW update and there was nothing mentioned in release notes.
                                  Ars Vitae Silver Members @Likarnik
                                  @Likarnik I appreciate the information. Thanks.
                                  • AudaxjoeA Offline
                                    Audaxjoe @Ars Vitae
                                    @Ars-Vitae I cycle but don’t record cadence. So what ever Suunto did would not be perfect for everyone.
                                    Custom profile is the way to go. And very easy.
                                    Suunto 9 BARO
                                    Garmin Fenix 3, 5
                                    Suunto Vector
