    Battery life on Suunto 9 after Fall 2021 update
    24 Posts 12 Posters 4.5k Views 12 Watching
    • X Offline
      xdennisma
      I’ve had my Suunto 9 for several years and have always had excellent battery life out of it. I did a regular update in the fall of 2021, and ever since then the battery life when not in use has been terrible. I only use it for runs/exercise (about 30-60 minutes a day), and otherwise it sits on my shelf, yet the battery runs down by 15-20% per day. I have no media settings on and do not receive notifications on it. I need to charge my watch twice a week instead of once or twice a month.
      I found several threads from August and September 2021 about a firmware update causing this issue, but do not see a solution amongst the thread replies. My watch is up to date for all updates. Am I missing something? Is there something I need to do to get back the regular battery life? Thanks!
      surfboomerangS Adam GibsonA 2 Replies Last reply Reply Quote 3
        surfboomerang @xdennisma
        @xdennisma apparently this issue has been fixed in the upcoming firmware. Only Suunto knows when it will be released. So all we can do is wait
          I can confirm that this is fixed in preproduction firmware. My guess is that there is not much to wait 😉
          surfboomerangS D Juan Ignacio Quesada BustosJ 3 Replies Last reply Reply Quote 10
            surfboomerang @isazi
            @isazi Small side step…
            We know that the dual constellation selection like GPS + GLONASS/GALILEO affects battery estimation. Selecting GPS + Beidou however doesn’t. Is there indeed no battery impact by selecting Beidou or is it a bug?
            Łukasz SzmigielŁ isaziI 2 Replies Last reply Reply Quote 0
              dulko79 @isazi
              @isazi good things come to those who wait 😄
              App: beta
              Phone: Iphone
              iOS
              • Łukasz SzmigielŁ Offline
                Łukasz Szmigiel @surfboomerang
                @surfboomerang I assume it’s because Beidou is less precise / faster to calculate.
                S9PP 2.50.28
                  @surfboomerang to my knowledge is not a bug, I am not sure why, maybe Beidou works on the same frequency as GPS.
                  Anyway the bug was on daily mode, not during activity, and the strange thing is that it was not affecting everyone equally: some people saw worse battery life than others.
                  surfboomerangS 1 Reply Last reply Reply Quote 2
                    @isazi Yeah, I have to daily mode bug too which shortens the life of my S9P with roughly 25%.
                    But reading about battery bug, I remembered the behavior of the constellation selection. Hence the side step 🙂
                    Djordje SD 1 Reply Last reply Reply Quote 0
                    • Djordje SD Offline
                      Djordje S Bronze Member @surfboomerang
                      @surfboomerang With one exercise per day battery drops around 25%……
                      • Juan Ignacio Quesada BustosJ Offline
                        Juan Ignacio Quesada Bustos @isazi
                        @isazi Speaking of problems with the firmware, do you know if the new firmware already corrects the error that when the alarm sounds the screen does not turn on and it is difficult to stop the beep? Since version 2.18.20 I have been observing this error, in versions previous ones did not happen.
                        • Adam GibsonA Offline
                          Adam Gibson @xdennisma
                          @xdennisma Glad I’m not the only one with this issue. 90% of the reason I chose this watch was so I wouldn’t have to charge it every day.
                          • X Offline
                            xdennisma
                            Thank you everyone for the replies. I had called in to Suunto a couple of times to see if they had a solution, but hadn’t even acknowledged that this is a known problem. Based on the confirmation from several of you above, I’ll just be patient and wait for the firmware update. But this regular charging is certainly an annoyance, given that I was used to not having to charge my watch regularly. Thanks!
                              DMytro @xdennisma
                              @xdennisma you know, you can roll back to the previous firmware, right?
                              The downside would be that you lose your settings as if you did a hard reset.
                              X 1 Reply Last reply Reply Quote 1
                              • X Offline
                                xdennisma @DMytro
                                @dmytro Interesting! No, I didn’t know that. My only relevant settings are stored on the Suunto App, so I could just re-sync and recover them. Where can I find instructions on how to roll back? I just did a quick web search and can’t find anything that looks reputable.
                                freeheelerF surfboomerangS 2 Replies Last reply Reply Quote 0
                                  freeheeler @xdennisma
                                  @xdennisma said in Battery life on Suunto 9 after Fall 2021 update:
                                  really? that’s new to me…
                                    @xdennisma all knowledge is available on this forum.
                                    https://forum.suunto.com/search?term=Rollback&in=titlesposts&matchWords=all&sortBy=relevance&sortDirection=desc&showAs=posts
                                    https://forum.suunto.com/topic/7334/suunto-5-battery/11?_=1641531340906
                                      freeheeler @surfboomerang
                                      @surfboomerang
                                      for one second I was dreaming backup was implemented and we didn’t know 😉
                                        surfboomerang @freeheeler
                                        @freeheeler No, still no backup unfortunately. Maybe someday… 🙏
                                          Just wait. Till the end of the month if all goes good should be out.
                                          surfboomerangS 1 Reply Last reply Reply Quote 14
                                            @dimitrios-kanellopoulos
                                            You mean the backup function? 😯
                                            Or the new firmware? 😳
                                            Or…both? 😍
                                            EgikaE 1 Reply Last reply Reply Quote 5
