    Custom training? Pulse or speed warning?
    12 Posts 6 Posters 676 Views 6 Watching
    • Kristoffer RehnstedtK Offline
      Hi!
      Is it possible to create a custom training for the Suunto 7 like run within a pulse range like between x-y and if it goes lower or higher it vibrates?
      Or run within a speed range between x-y?
      Brad_OlwinB ? 3 Replies Last reply Reply Quote 0
        Brad_Olwin Moderator @Kristoffer Rehnstedt
        @kristoffer-rehnstedt You can do this by setting a zone from Intensity zones for Pace, HR or Power. There is also a simple interval set up you can set as well. I don’t know if this answers your question.
        Kristoffer RehnstedtK Guillermo Ortega CerroG 2 Replies Last reply Reply Quote 0
          Kristoffer Rehnstedt @Brad_Olwin
          @brad_olwin Great!
          Next question, how do I do it?
            Egika Platinum Member
            afaik this is not possible with the Suunto 7 built in Suunto Wear App.
            Possibly a 3rd party app like Google Fit, Ghost Runner My Sporty Go etc. can do this?
            The Suunto 5 and 9 also have this functionality.
            • Guillermo Ortega CerroG Offline
              Guillermo Ortega Cerro @Brad_Olwin
              @brad_olwin With S7 and SuuntoAPP it is not possible 😧
                This post is deleted!
                  @kristoffer-rehnstedt said in Custom training? Pulse or speed warning?:
                  Hi!
                  My BAD! So sorry, did not see this was in S7, this is not possible but there are a number of third party timing apps that will allow this.
                    A Former User @Kristoffer Rehnstedt
                    Hi!
                    I use heart rate alert; one vibration: below threshold user defined MIN BPM
                    two quick vibrations: above the MAX user BPM
                    I use interval timer, a great app that gives me that function. so I can sometimes have quite a few apps running
                    KajkomK 1 Reply Last reply Reply Quote 1
                    • KajkomK Offline
                      Kajkom @Guest
                      @r-s-0
                      can I ask you to send a link to the application you are writing?
                        Egika Platinum Member @Kajkom
                        @kajkom https://play.google.com/store/apps/details?id=com.solutions.itech.novus.heartratealert
                        KajkomK ? 2 Replies Last reply Reply Quote 0
                        • KajkomK Offline
                          Kajkom @Egika
                          @egika thank you very much
                            A Former User @Egika
                            @egika that very same!
                            Also, I suggest interval timer app (works great).
                            For speed you can use ghostracer and a previous run or some programmed paced ghost track to follow for different kms and have it in the forefront to keep the speed difference to 0 with the ghost.
