    Ambit Apps Compilation
    44 Posts 15 Posters 10.2k Views 18 Watching
    • Z Offline
      zt_zzzzz
      The trial is OK, thank you!
      • C Offline
        Christos Palikaras
        @pavel-samokha Thank you for the implementation!
        I’ve created the below app, but when trying to create or edit a sport mode, displays are not loading.
        curl --location --request POST 'https://ambitappscompiler.azurewebsites.net/api/compile' \
        --header 'x-functions-key: qakj8vb/62VgzmSl19mDQzRmW7nCSDv0zAo2A1aC3ldfd8U8r5jksA==' \
        --header 'Content-Type: text/plain' \
        --data-raw '/* Duration App */
        /* Interval 1 */
        /* Initialize variables */
        if (SUUNTO_DURATION == 0) {
          RESULT = 0;
        /* Lap 1, 2 is step type Interval with duration type Time */
        if (SUUNTO_LAP_NUMBER == 1 || SUUNTO_LAP_NUMBER == 2) {
          prefix = "int";
          postfix = "s";
          RESULT = 5 - SUUNTO_LAP_DURATION;
        /* Lap 3 is step type Interval with duration type Time */
        if (SUUNTO_LAP_NUMBER == 3) {
          prefix = "int";
          postfix = "s";
          RESULT = 10 - SUUNTO_LAP_DURATION;
        /* Lap 4, 5, 6 is step type Interval with duration type Time */
        if (SUUNTO_LAP_NUMBER == 4 || SUUNTO_LAP_NUMBER == 5 || SUUNTO_LAP_NUMBER == 6) {
          prefix = "int";
          postfix = "s";
          RESULT = 15 - SUUNTO_LAP_DURATION;
        /* Lap 7 is step type Interval with duration type Time */
        if (SUUNTO_LAP_NUMBER == 7) {
          prefix = "int";
          postfix = "s";
          RESULT = 20 - SUUNTO_LAP_DURATION;
        /* Check if duration is reached */
        if (RESULT < 0) {
          RESULT = 0;
          /* Alert that duration is reached */
          Suunto.alarmBeep();
          Suunto.light();
        • pavel.samokhaP Offline
          pavel.samokha @Christos Palikaras
          @christos-palikaras I guess corrupted index.json may be cause this. I’ll try to update doc with more detailed instructions.
          • C Offline
            Christos Palikaras @pavel.samokha
            @pavel-samokha It seems that the output of the Compiler UI should be an array of json objects. That fixed my issue.
            pavel.samokhaP 1 Reply Last reply Reply Quote 1
              @christos-palikaras yes, in index.json it’s an JSON array, but compiler output is one json object with assumption that user might want to add it to existing array of apps, not replacing it completely with one.
              • Z Offline
                zt_zzzzz
                share Power_Zone:
                /FTP=SUUNTO_USER_HEIGHT+100; Because SUUNTO_USER_HEIGHT≤250;of course you can +200 or +300/
                /*FTP=SUUNTO_USER_HEIGHT+100; Because SUUNTO_USER_HEIGHT≤250;*/
                RESULT = 0;
                if(SUUNTO_BIKE_POWER_AVG[3] < FTP * 25/100) {
                  RESULT=( 0 + (SUUNTO_BIKE_POWER_AVG[3] / (FTP * 25/100)) );postfix="Rest";
                else if (SUUNTO_BIKE_POWER_AVG[3] < FTP * 55/100) {
                  RESULT=(1 + ( ( SUUNTO_BIKE_POWER_AVG[3] - (FTP * 25/100) ) / ( (FTP * 55/100) - (FTP * 25/100) ) ) ) ;postfix="Rec";
                else if (SUUNTO_BIKE_POWER_AVG[3]>FTP * 55/100 && SUUNTO_BIKE_POWER_AVG[3]< FTP * 75/100)
                 {RESULT=(2 + ( ( SUUNTO_BIKE_POWER_AVG[3] - (FTP * 55/100) ) / ( (FTP * 75/100) - (FTP * 55/100) ) ) );postfix="End"; }
                else if (SUUNTO_BIKE_POWER_AVG[3]>FTP * 75/100 && SUUNTO_BIKE_POWER_AVG[3] < FTP * 90/100)
                {RESULT=(3 + ( ( SUUNTO_BIKE_POWER_AVG[3] - (FTP * 75/100) ) / ( (FTP * 90/100) - (FTP * 75/100) ) ) ) ;postfix="Temp"; }
                else if (SUUNTO_BIKE_POWER_AVG[3]> FTP * 90/100 && SUUNTO_BIKE_POWER_AVG[3]< FTP* 105/100 )
                      {RESULT=(4 + ( ( SUUNTO_BIKE_POWER_AVG[3] - (FTP * 90/100) ) / ( (FTP * 105/100) - (FTP * 90/100) ) ) );postfix="Thresh"; }
                else if(SUUNTO_BIKE_POWER_AVG[3]> FTP * 105/100 && SUUNTO_BIKE_POWER_AVG[3]< FTP * 120/100)
                      {RESULT=(5 + ( ( SUUNTO_BIKE_POWER_AVG[3] - (FTP * 105/100) ) / ( (FTP * 120/100) - (FTP * 105/100) ) ) ) ;postfix="VO2M"; }
                else if(SUUNTO_BIKE_POWER_AVG[3]> FTP * 120/100 && SUUNTO_BIKE_POWER_AVG[3]< FTP * 150/100)
                    {RESULT=(6 + ( ( SUUNTO_BIKE_POWER_AVG[3] - (FTP * 120/100) ) / ( (FTP * 150/100) - (FTP * 120/100) ) ) );postfix="Anaer"; }
                else if (SUUNTO_BIKE_POWER_AVG[3] > FTP * 150/100 )
                   {RESULT=(7 + ( ( SUUNTO_BIKE_POWER_AVG[3] - (FTP * 150/100) ) / ( 2000 - (FTP * 150/100) ) ) ) ;postfix="SPRINT"; }
                [json]
                {"ruleId":11000004,"name":"Power_Zone","categoryId":0,"activityId":1,"userCount":1,"binary":[73,65,77,82,85,76,69,0,8,0,0,0,1,0,0,0,1,0,0,0,0,0,0,0,130,0,0,0,42,0,50,0,60,0,70,0,80,0,88,0,110,0,0,0,114,117,108,101,48,0,255,191,82,69,83,85,76,84,0,0,255,63,112,111,115,116,102,105,120,0,255,63,112,114,101,102,105,120,0,0,255,63,116,105,116,108,101,0,85,0,83,85,85,78,84,79,95,85,83,69,82,95,72,69,73,71,72,84,0,0,69,0,83,85,85,78,84,79,95,66,73,75,69,95,80,79,87,69,82,0,4,0,2,0,21,0,0,0,0,0,0,0,0,0,0,0,0,0,4,0,1,0,0,0,0,0,2,0,0,0,32,0,7,0,0,0,0,0,6,0,0,0,32,0,1,0,0,0,0,0,14,0,0,0,32,0,1,0,0,0,0,0,16,0,0,0,4,0,1,0,0,0,0,0,18,0,0,0,4,0,4,0,0,0,0,0,22,0,0,0,4,0,0,0,0,0,0,0,38,0,0,0,4,0,0,0,0,0,0,0,42,0,0,0,160,0,1,0,0,0,0,0,0,0,0,0,4,0,0,0,0,0,0,0,46,0,0,0,4,0,0,0,0,0,0,0,50,0,0,0,4,0,0,0,0,0,0,0,54,0,0,0,160,0,5,0,0,0,0,0,2,0,0,0,160,0,4,0,0,0,0,0,8,0,0,0,160,0,4,0,0,0,0,0,12,0,0,0,160,0,5,0,0,0,0,0,16,0,0,0,160,0,7,0,0,0,0,0,22,0,0,0,160,0,5,0,0,0,0,0,30,0,0,0,160,0,6,0,0,0,0,0,36,0,0,0,160,0,7,0,0,0,0,0,42,0,0,0,58,0,50,0,0,0,82,101,115,116,0,0,82,101,99,0,69,110,100,0,84,101,109,112,0,0,84,104,114,101,115,104,0,0,86,79,50,77,0,0,65,110,97,101,114,0,83,80,82,73,78,84,0,0,52,3,28,7,0,22,32,0,144,0,0,0,0,21,8,0,25,16,9,24,89,2,0,25,16,9,24,89,3,0,25,16,9,24,89,4,0,16,1,21,7,0,28,5,0,28,6,0,12,22,6,0,13,0,3,18,252,2,144,0,0,64,64,21,10,0,20,10,0,144,0,0,0,0,7,22,48,0,20,10,0,144,0,0,128,191,1,144,0,0,128,63,1,84,6,0,20,10,0,144,0,0,128,63,1,85,6,0,20,10,0,144,0,0,128,191,1,21,10,0,13,202,255,144,0,0,0,0,21,11,0,144,0,0,128,63,21,10,0,20,10,0,144,0,0,128,64,5,22,61,0,20,11,0,20,10,0,144,0,0,128,63,1,84,6,0,1,21,11,0,20,10,0,144,0,0,64,64,9,22,15,0,20,11,0,144,171,170,170,62,3,21,8,0,20,10,0,144,0,0,128,63,1,21,10,0,13,189,255,144,0,0,0,0,21,1,0,20,5,0,144,0,0,200,66,1,21,12,0,20,8,0,20,12,0,144,0,0,128,62,3,5,22,35,0,20,8,0,20,12,0,144,0,0,128,62,3,4,144,0,0,0,0,1,21,1,0,25,16,13,24,89,2,0,13,30,2,20,8,0,20,12,0,144,205,204,12,63,3,5,22,55,0,20,8,0,20,12,0,144,0,0,128,62,3,2,20,12,0,144,205,204,12,63,3,20,12,0,144,0,0,128,62,3,2,4,144,0,0,128,63,1,21,1,0,25,16,14,24,89,2,0,13,218,1,20,8,0,20,12,0,144,205,204,12,63,3,7,20,8,0,20,12,0,144,0,0,64,63,3,5,11,22,55,0,20,8,0,20,12,0,144,205,204,12,63,3,2,20,12,0,144,0,0,64,63,3,20,12,0,144,205,204,12,63,3,2,4,144,0,0,0,64,1,21,1,0,25,16,15,24,89,2,0,13,136,1,20,8,0,20,12,0,144,0,0,64,63,3,7,20,8,0,20,12,0,144,102,102,102,63,3,5,11,22,55,0,20,8,0,20,12,0,144,0,0,64,63,3,2,20,12,0,144,102,102,102,63,3,20,12,0,144,0,0,64,63,3,2,4,144,0,0,64,64,1,21,1,0,25,16,16,24,89,2,0,13,54,1,20,8,0,20,12,0,144,102,102,102,63,3,7,20,8,0,20,12,0,144,102,102,134,63,3,5,11,22,55,0,20,8,0,20,12,0,144,102,102,102,63,3,2,20,12,0,144,102,102,134,63,3,20,12,0,144,102,102,102,63,3,2,4,144,0,0,128,64,1,21,1,0,25,16,17,24,89,2,0,13,228,0,20,8,0,20,12,0,144,102,102,134,63,3,7,20,8,0,20,12,0,144,154,153,153,63,3,5,11,22,55,0,20,8,0,20,12,0,144,102,102,134,63,3,2,20,12,0,144,154,153,153,63,3,20,12,0,144,102,102,134,63,3,2,4,144,0,0,160,64,1,21,1,0,25,16,18,24,89,2,0,13,146,0,20,8,0,20,12,0,144,154,153,153,63,3,7,20,8,0,20,12,0,144,0,0,192,63,3,5,11,22,55,0,20,8,0,20,12,0,144,154,153,153,63,3,2,20,12,0,144,0,0,192,63,3,20,12,0,144,154,153,153,63,3,2,4,144,0,0,192,64,1,21,1,0,25,16,19,24,89,2,0,13,64,0,20,8,0,20,12,0,144,0,0,192,63,3,7,22,48,0,20,8,0,20,12,0,144,0,0,192,63,3,2,144,0,0,250,68,20,12,0,144,0,0,192,63,3,2,4,144,0,0,224,64,1,21,1,0,25,16,20,24,89,2,0,13,4,0,19,31,0],"compatibleVariants":["Colibri","Duck","Emu","Finch","Kaka"]}
                • pavel.samokhaP pavel.samokha referenced this topic on
                • Z zt_zzzzz referenced this topic on
                  divy2 @zt_zzzzz
                  @@pavel.samokha
                  Hi! This looks great, but I don’t understand a lot of this. I allways created my apps with the intervall designer: http://www.ambitintervals.com/#!/ and movescount web was the way to get it into the Ambit.
                  I was wondering how to get this apps now into the list of apps in suuntolink and someone told me that I should have a look at this posts. Well, the app generator produces the app I paste under this lines. But the result is this:
                  This is the app pasted in the compiler. Is there any way to get it worked?
                  /* Target App */
                  /* Interval 1 */
                  ACTUAL = 0;
                  TO = 0;
                  FROM = 0;
                  FORMATPACE = 0;
                  TARGET = 0;
                  TARGETSEC = 0;
                  TARGETMIN = 0;
                  RESULT = 0;
                  /* Lap 1 is step type WarmUp with target type None */
                  if (SUUNTO_LAP_NUMBER == 1) {
                  ACTUAL = SUUNTO_PACE * 60;
                  FROM = ACTUAL;
                  TO = ACTUAL;
                  FORMATPACE = 1;
                  postfix = “/km”;
                  /* Lap 2, 3, 4 is step type Interval with target type Pace */
                  if (SUUNTO_LAP_NUMBER == 2 || SUUNTO_LAP_NUMBER == 3 || SUUNTO_LAP_NUMBER == 4) {
                  FROM = 320;
                  TO = 310;
                  FORMATPACE = 1;
                  postfix = “/km”;
                  /* Lap 5 is step type Recovery with target type None */
                  if (SUUNTO_LAP_NUMBER == 5) {
                  FROM = ACTUAL;
                  TO = ACTUAL;
                  FORMATPACE = 1;
                  postfix = “/km”;
                  /* Lap 6, 8, 10, 12 is step type Interval with target type Pace */
                  if (SUUNTO_LAP_NUMBER == 6 || SUUNTO_LAP_NUMBER == 8 || SUUNTO_LAP_NUMBER == 10 || SUUNTO_LAP_NUMBER == 12) {
                  FROM = 295;
                  TO = 305;
                  FORMATPACE = 1;
                  postfix = “/km”;
                  /* Lap 7, 9, 11, 13 is step type Recovery with target type None */
                  if (SUUNTO_LAP_NUMBER == 7 || SUUNTO_LAP_NUMBER == 9 || SUUNTO_LAP_NUMBER == 11 || SUUNTO_LAP_NUMBER == 13) {
                  FROM = ACTUAL;
                  TO = ACTUAL;
                  FORMATPACE = 1;
                  postfix = “/km”;
                  /* Lap 14 is step type CoolDown with target type None */
                  if (SUUNTO_LAP_NUMBER == 14) {
                  FROM = ACTUAL;
                  TO = ACTUAL;
                  FORMATPACE = 1;
                  postfix = “/km”;
                  /* Set target value */
                  if (ACTUAL > TO) {
                  TARGET = TO;
                  } else if (ACTUAL < FROM) {
                  TARGET = FROM;
                  } else {
                  TARGET = ACTUAL;
                  /* Check if result should be formatted as pace and lables reversed */
                  if (FORMATPACE == 1) {
                  if (ACTUAL > TO) {
                  prefix ="up";
                  prefix = "dwn";
                  } else {
                  prefix = "ok";
                  TARGETSEC = Suunto.mod(TARGET, 60);
                  TARGETMIN = (TARGET - TARGETSEC) / 60;
                  RESULT = TARGETMIN + TARGETSEC/100;
                  } else {
                  if (ACTUAL > TO) {
                  prefix ="dwn";
                  prefix = "up";
                  } else {
                  prefix = "ok";
                  RESULT = TARGET;
                    divy2 @divy2
                    The same result happens with the app that started this threat. No display in Suuntolink.
                    I only paste the result of the Ambit App Compiler into index.json opened in the note pad in windows. What I’m doing wrong?
                    D sebchastangS 2 Replies Last reply Reply Quote 0
                      divy2 @divy2
                      Well, not exactly, but when I paste the result of the compiler to index.json, suuntolink shows “Select Suunto App (0)”, where before it showed “Select Suunto App (13104)”.
                      • sebchastangS Offline
                        sebchastang Silver Members @divy2
                        @divy2 Hi,
                        Maybe your index.json is not valid because you just pasted the result of the compiler without surrounding it by [ and ]
                        Result should be like this in your .json file :
                        [{“ruleId”:11000001,“name”:“Ambit App”,“categoryId”:0,“activityId”:1,“userCount”:1,“binary”:[73,65,77,82,85,76,69,0,8,0,0,0,1,0,0,0,1,0,0,0,0,0,0,0,142,0,0,0,44,0,52,0,62,0,72,0,82,0,90,0,108,0,128,0,0,0,114,117,108,101,48,0,255,191,82,69,83,85,76,84,0,0,255,63,112,111,115,116,102,105,120,0,255,63,112,114,101,102,105,120,0,0,255,63,116,105,116,108,101,0,11,0,83,85,85,78,84,79,95,68,85,82,65,84,73,79,78,0,25,0,83,85,85,78,84,79,95,76,65,80,95,78,85,77,66,69,82,0,2,0,83,85,85,78,84,79,95,80,65,67,69,0,4,0,3,0,21,0,0,0,0,0,0,0,0,0,0,0,0,0,4,0,1,0,0,0,0,0,2,0,0,0,32,0,4,0,0,0,0,0,6,0,0,0,32,0,4,0,0,0,0,0,10,0,0,0,32,0,1,0,0,0,0,0,14,0,0,0,4,0,1,0,0,0,0,0,16,0,0,0,4,0,1,0,0,0,0,0,20,0,0,0,4,0,1,0,0,0,0,0,24,0,0,0,4,0,0,0,0,0,0,0,28,0,0,0,160,0,1,0,0,0,0,0,0,0,0,0,4,0,0,0,0,0,0,0,32,0,0,0,4,0,0,0,0,0,0,0,36,0,0,0,4,0,0,0,0,0,0,0,40,0,0,0,4,0,0,0,0,0,0,0,44,0,0,0,4,0,0,0,0,0,0,0,48,0,0,0,4,0,0,0,0,0,0,0,52,0,0,0,4,0,0,0,0,0,0,0,56,0,0,0,160,0,4,0,0,0,0,0,2,0,0,0,160,0,3,0,0,0,0,0,6,0,0,0,160,0,4,0,0,0,0,0,10,0,0,0,160,0,3,0,0,0,0,0,14,0,0,0,60,0,18,0,0,0,47,107,109,0,117,112,0,0,100,119,110,0,111,107,0,0,60,3,28,8,0,22,80,0,25,16,9,24,89,2,0,25,16,9,24,89,3,0,25,16,9,24,89,4,0,144,0,0,0,0,21,10,0,144,0,0,0,0,21,11,0,144,0,0,0,0,21,12,0,144,0,0,0,0,21,13,0,144,0,0,0,0,21,14,0,144,0,0,0,0,21,15,0,144,0,0,0,0,21,16,0,16,1,21,8,0,28,5,0,28,6,0,12,28,7,0,12,22,6,0,13,213,2,18,209,2,20,5,0,144,0,0,0,0,9,22,67,0,144,0,0,0,0,21,10,0,144,0,0,0,0,21,11,0,144,0,0,0,0,21,12,0,144,0,0,0,0,21,13,0,144,0,0,0,0,21,14,0,144,0,0,0,0,21,15,0,144,0,0,0,0,21,16,0,144,0,0,0,0,21,1,0,20,6,0,144,0,0,128,63,9,22,48,0,20,7,0,144,134,143,136,60,3,144,0,0,112,66,3,21,10,0,20,10,0,21,12,0,20,10,0,21,11,0,144,0,0,128,63,21,13,0,25,16,17,24,89,2,0,20,6,0,144,0,0,0,64,9,20,6,0,144,0,0,64,64,9,12,20,6,0,144,0,0,128,64,9,12,22,52,0,20,7,0,144,134,143,136,60,3,144,0,0,112,66,3,21,10,0,144,0,0,160,67,21,12,0,144,0,0,155,67,21,11,0,144,0,0,128,63,21,13,0,25,16,17,24,89,2,0,20,6,0,144,0,0,160,64,9,22,48,0,20,7,0,144,134,143,136,60,3,144,0,0,112,66,3,21,10,0,20,10,0,21,12,0,20,10,0,21,11,0,144,0,0,128,63,21,13,0,25,16,17,24,89,2,0,20,6,0,144,0,0,192,64,9,20,6,0,144,0,0,0,65,9,12,20,6,0,144,0,0,32,65,9,12,20,6,0,144,0,0,64,65,9,12,22,52,0,20,7,0,144,134,143,136,60,3,144,0,0,112,66,3,21,10,0,144,0,128,147,67,21,12,0,144,0,128,152,67,21,11,0,144,0,0,128,63,21,13,0,25,16,17,24,89,2,0,20,6,0,144,0,0,224,64,9,20,6,0,144,0,0,16,65,9,12,20,6,0,144,0,0,48,65,9,12,20,6,0,144,0,0,80,65,9,12,22,48,0,20,7,0,144,134,143,136,60,3,144,0,0,112,66,3,21,10,0,20,10,0,21,12,0,20,10,0,21,11,0,144,0,0,128,63,21,13,0,25,16,17,24,89,2,0,20,6,0,144,0,0,96,65,9,22,48,0,20,7,0,144,134,143,136,60,3,144,0,0,112,66,3,21,10,0,20,10,0,21,12,0,20,10,0,21,11,0,144,0,0,128,63,21,13,0,25,16,17,24,89,2,0,20,10,0,20,11,0,7,22,12,0,20,11,0,21,14,0,13,28,0,20,10,0,20,12,0,5,22,12,0,20,12,0,21,14,0,13,9,0,20,10,0,21,14,0,20,13,0,144,0,0,128,63,9,22,103,0,20,10,0,20,11,0,7,22,13,0,25,16,18,24,89,3,0,13,30,0,20,10,0,20,12,0,5,22,13,0,25,16,19,24,89,3,0,13,10,0,25,16,20,24,89,3,0,20,14,0,144,0,0,112,66,33,16,0,1,0,2,0,21,15,0,20,14,0,20,15,0,2,144,137,136,136,60,3,21,16,0,20,16,0,20,15,0,144,10,215,35,60,3,1,21,1,0,13,56,0,20,10,0,20,11,0,7,22,13,0,25,16,19,24,89,3,0,13,30,0,20,10,0,20,12,0,5,22,13,0,25,16,18,24,89,3,0,13,10,0,25,16,20,24,89,3,0,20,14,0,21,1,0,13,4,0,19,31],“compatibleVariants”:[“Bluebird”,“Colibri”,“Duck”,“Emu”,“Finch”,“Greentit”,“Ibisbill”,“Jabiru”,“Kaka”,“Loon”]}]
                        I hope it helps, let us know.
                        Suunto Traverse
                        D 1 Reply Last reply Reply Quote 3
                          divy2 @sebchastang
                          Hey, @sebchastang, it worked! You’re right, the problem has been the [ and ]. Now I’ve the app in the watch. Tomorrow I’ll see how it works. I’ve been looking for a Garmin already, but maybe it won’t be necesary.
                          Thanks a lot! 😉
                          sebchastangS 1 Reply Last reply Reply Quote 1
                            @divy2 great! 👍
                            Suunto Traverse
                            D 2 Replies Last reply Reply Quote 0
                              divy2 @sebchastang
                              Hi!
                              It worked @sebchastang, I just had a few issues with the way I programmed the app with the interval generator. My mistake! 😉
                              Anyway, it works, but that’s not entirely comfortable. I think I’ll go for a new (used) watch, probably Garmin, even if they’re pretty ugly compared to Suunto. I think would be pretty stupid to choose another Suunto after the treatment we Ambit users have received and also because Suunto could repeat what they did with the Ambits with other watches after a while, which are working fine now. That’s pretty sad, but it’s like or as we say in Spanish, it’s like lentils. Eat them or leave them. Suunto’s sales department doesn’t even have an email address to talk to about it. Maybe I could still be persuaded. Well…
                              Thank you for your help here!
                                divy2 @sebchastang
                                Well, it works but still have a problem, @sebchastang.
                                Now I changed the intervals and gave them another name, Jens1 and Jens2. But I can’t click on them in suuntolink, nothing happens.
                                There are two trainings in the index.json-file, Jens1 and Jens2, which begins like this:
                                [{“ruleId”:11000001,“name”: “Jens1”,“categoryId”:0,“activityId”:1,“userCount”:1,“binary”:[73,65,77,82,85,76
                                But as you see in the screenshot suuntolink shows them, but I can’t choose them, theire are still the old ones to choose: Ambit App, Ambit App2 and again Ambit App. These 3 apps even still apear when I change the name of the index.json-file, so there should me nothing. But only in Suunto Apps I see Select Suunto App (0), but the three old apps are still down there. What I’m doing wrong?
                                  divy2 @divy2
                                  Sorry, another update: I can choose Jens2, but not Jens1. It’s there, but nothing happens if I click on it. Uff…
                                  edit: Ok, this is fixed. The reason was quite simply and funny: I generated two identical workouts, only with diferent names. No it worked. Sorry for pasting such a lot of problemas, but maybe it will help other users.
                                  • Fábio VeríssimoF Offline
                                    Fábio Veríssimo
                                    amazing!
                                    It took me 10 months to find this?!
                                    not the most straight fwr way to transfer Humango intervals to my Ambit3, but I’ll take that while I wait for the next iteration of the Suunto 5.
                                    Suunto Ambit3 Sport
                                    Garmin Edge 530
                                    Garmin FR255s
                                      divy2 @divy2
                                      Sorry, wanted to say "now it works, not no it works. And “problemas” are “problems”, 😳
                                        @divy2 Good! Remember you have to set unique “ruleid” for each app.
                                        I also noticed some issues when I update my apps, I need to select them, save sport mode and then re-enter into the sport mode and re-select them again.
                                        Even if it is not very comfortable, it is cool to still be able to use suunto apps 👍
                                        Suunto Traverse
                                          divy2 @sebchastang
                                          Yes, @sebchastang, I changed the “ruleId”:11000001" into …00002, .00003 and so on.
                                          In about two hours I’ll be out to try it. And you’re right, it’s great that this way we can still program apps. Thank you so much for the people who worked this out!
                                          But it’s dificult to forget what Suunto did with this realy great Ambits which are still so raliables!
                                          • H halajos referenced this topic on
                                          • Dubosson AurélienD Offline
                                            Dubosson Aurélien
                                            Hello everyone,
                                            I’m trying to create a new app to monitor my zone 2 (core endurance.
                                            The code I’m trying to compile is the following:
                                            if(SUUNTO_HR_AVG[5]<(70/100*(184–70)+70) || SUUNTO_HR_AVG[5]>(75/100*(184–70)+70))
                                            Suunto.alarmBeep();
                                            but I encounter everytime an issue:
                                            “[ErrorCode, COMPILATION_FAILED]\r\n[ErrorLine, 1]\r\n[ErrorColumn, 33]”
                                            Is anyone have an idea what is causing this error ?
                                            Thanks in advance.
                                            Kind regards.
                                            Narglix
                                            Raimo JärviR sebchastangS 2 Replies Last reply Reply Quote 0
