    S9 columns display problem (bug?!)
    31 Posts 4 Posters 1.5k Views 4 Watching
    • gerasimosG Offline
      gerasimos Bronze Member
      does not show me the data correctly at columns display ( in the three options )
      1. reset watch
      2. reset phone
      3. update app/watch
      4. delete sport profile trail running / renew
      set in S9 column - lap number / lap distance / lap asc / lap duration and dont work correctly **it only shows me always the first effort only **
      Suunto Vertical Ti
      Suunto S9 gen1
      Suunto Ambit3 peak
      freeheelerF isaziI ? 3 Replies Last reply Reply Quote 1
        freeheeler @gerasimos
        @gerasimos
        did you try with autolaps, too?
        gerasimosG 1 Reply Last reply Reply Quote 0
          gerasimos Bronze Member @freeheeler
          @freeheeler autolap works fine! The data is ok.
          With manual is the problem
          Suunto Vertical Ti
          Suunto S9 gen1
          Suunto Ambit3 peak
            gerasimos Bronze Member @gerasimos
            @gerasimos after autolap looks ok and manual…strange…suunto crazy thinks.
            Suunto Vertical Ti
            Suunto S9 gen1
            Suunto Ambit3 peak
              @gerasimos
              I think I remember we’ve seen a similar behaviour in SA activity summary with auto vs manual laps some time ago.
                isazi Moderator @gerasimos
                @gerasimos show me a screenshot of the sport configuration, I will replicate and check with testing firmware.
                gerasimosG 1 Reply Last reply Reply Quote 2
                  @freeheeler @isazi ok man and thanks for help…
                  Now working ok after engage autolap.
                  I turned it off and try manually…and now its everything ok something like " stuck " and i notice dont keep in the memory the battery settings… after end the activities.
                  Screenshot_2022-05-05-20-50-54-511_com.stt.android.suunto.jpg Screenshot_2022-05-05-20-51-00-144_com.stt.android.suunto.jpg Screenshot_2022-05-05-20-51-04-000_com.stt.android.suunto.jpg
                  Suunto Vertical Ti
                  Suunto S9 gen1
                  Suunto Ambit3 peak
                    gerasimos Bronze Member @isazi
                    @isazi after second reset and delete memory cash in suunto app everything works perfect 💪🔺
                    Suunto Vertical Ti
                    Suunto S9 gen1
                    Suunto Ambit3 peak
                      @gerasimos great to hear this!
                        freeheeler @isazi
                        maybe this is something to report anyway?
                        because when I tried with manual laps it was the same as for @gerasimos but it doesn’t make sense to initiate autolaps first to trigger manual laps later, right?
                          I am testing now.
                            Okay the issue for me seems to be this: if you enable autolaps the manual laps are not visible in the “lap table” view (only the auto one are). If you don’t have autolaps then you see the manual laps. I am not sure if this is a bug, or by design. I will ask.
                              freeheeler @isazi
                              it could well be that manual laps override autolaps, which would make sense because once you push the lap button the watch assumes your training is according to manual laps and then autolaps don’t make sense anymore.
                              but maybe since you’ve tried autolaps, manual laps are now working, too? (cache issue that @gerasimos describes).
                              I’ve never tried this list with autolaps before, only today with manual laps: same behavior as @gerasimos says
                                freeheeler
                                did a test, too.
                                cycling custom activity worked immediately with manual laps.
                                  @freeheeler exactly that is the problem…man!!
                                  Sorry my English very bad
                                  Suunto Vertical Ti
                                  Suunto S9 gen1
                                  Suunto Ambit3 peak
                                    @gerasimos
                                    I’ve tried both. Manual laps work and auto laps work, too.
                                    If you have auto laps activated and you press manual lap, then it is not shown in the list.
                                    But then I don’t understand the problem? 🙂 don’t worry about languages, they’re just communication tools 😉
                                    gerasimosG 1 Reply Last reply Reply Quote 1
                                      I asked if this is the intended behavior or not, an answer should come soon. I tend to think that this is the intended behavior, and not a bug.
                                        @freeheeler The problem is in Manual Autolap shows me only the first attempt with Autolap Off.
                                        E.g.
                                        1. Manual lap + autolap OFF = problem (saw first attempt always
                                        2. Manual + autolap ON = saw me autolaps work correct
                                        3. Turned OFF autolap = automatically fixed the manual lap problem with magic way 🙃
                                        Suunto Vertical Ti
                                        Suunto S9 gen1
                                        Suunto Ambit3 peak
                                          @gerasimos
                                          that is what @isazi suspects: it could be to work this way by intention.
                                          you have to decide before the activity: manual or auto.
                                          if you pic auto and the press manual lap button it will not work.
                                          if you switch off auto and then press manual lap button it will work.
                                          to me it makes sense this way, because you either want to know every certain km, e.g. 1km as a “lap” or a segment OR you have your trail that is not exactly 1km and you want to do laps on it and you press manually… both will only cause confusion in the list: which lap was which? auto or manual… do you know what I mean?
                                            @freeheeler yes very clear everything understand what you mean, the problem is in the start on activity.
                                            I choose autolap off from the beginning and i have the current problem with manual laps
                                            After soft reset and edit profile from beginning everything works perfect…( until now)
                                            The major problem is a lock button in time mode 😜😁
                                            Suunto Vertical Ti
                                            Suunto S9 gen1
                                            Suunto Ambit3 peak
