    Strava with SA not showing same HR values
    6 Posts 3 Posters 399 Views 3 Watching
    • thanasisT Offline
      thanasis Bronze Member
      Max HR on suunto app shows 184bpm on a tennis activity whereas Strava got the max equal to average (141) and hence all other values are wrong
      I posted it here for I don’t know where else to do so
        Dimitrios Kanellopoulos Community Manager @thanasis
        @thanasis are you using a belt ?
        • thanasisT Offline
          thanasis Bronze Member @Dimitrios Kanellopoulos
          @Dimitrios-Kanellopoulos not this time … just the watch
            @thanasis keep in mind that strava removes all non moving time samples. So this might explain it. Check the times if they match (duration|).
            IF that is the case you can easily bypass this , via pausing instantly. If strava sees a pause at the workout it wont try to apply its magic
            • thanasisT Offline
              @Dimitrios-Kanellopoulos said in Strava with SA not showing same HR values:
              Thanks. But in tennis it is quite difficult to do that . Also there is no gps recording during the activity.it may be the case that they extrapolate the average HR to all value recordings. interesting! thanks
                freeheeler @thanasis
                @thanasis
                if in tennis mode available, select “race”
