    Running pace vs 965
    20 Posts 8 Posters 1.9k Views 7 Watching
      Just for the fun I am comparing the Ambit 3 with the 965 (multiband on).
      Results seem “identical” (let’s not forget the technology gap), but there is one thing that during the run is not identical, is the instant PACE.
      Like sometimes I see 6min/h on the 965 and at the same time 4:50min/km on the Ambit 3, but in the end the average is similar.
      Why does this happen? I am curious about the technical side of it.
      Also quite don’t understand why the ascent is the double on the garmin (but that I need to ask on the garmin forum), I believe ambit 3 is more correct, altough the innitial altitude is more correct on the 965.
      Have a great day
      zhang965Z MiniForkliftM 2 Replies Last reply Reply Quote 0
        zhang965 @Guest
        @André-Faria said in Running pace vs 965:
        Have a great day
        Hello André
        I do have good moment with ambit3/Spartan.
        They use SiRFstar gps chipset, and I didn’t see any speed drop during my run.
        With all Sony gps chipset, S9B s9p s9pp, I got a lot of speed drop during my run, for example if I run at 4min/km , the pace on watch will drop to 5 for a moment.
        If the speed gets a compensation, eg 3,30min/km, after 5 période, then my results will be fine in the end.
        But sometimes, if the compensation is not happening, then my gps is wrong.
        As 965 doesn’t use Sony chipset but has the same behavior, I think it’s the low-energy-consumption gps chipset 's commun behavior.
        Do you have any opportunity to compare Sony chipset Suunto vs Garmin?
        Br
        • TieutieuT Online
          Tieutieu Platinum Member
          I’ve never used Garmin but intensivly my S9B, after 4 also intense years with an A3P.
          And here is the point : I had a very precise and reactive instant pace with the A3P, very steady even when gps reception wasn’t so good, but I never had the same with the S9b (it moves all the Time).
          Average pace at the end are always good and it is quite normal as it is basically total time/ total distance.
          But during exercice, I have come to the conclusion that it highly depend on gps power/chipset and reliability.
          Better instant pace is one thing I hope to get back with my Vertical to come.
            zhang965 @Tieutieu
            @Tieutieu said in Running pace vs 965:
            Same here, but I think if Suunto is target for ultra long running, so they might not interested in the instant speed.
            It’s my pain point, if we can have something like gps boost mode for classic 5k 10l runners, it’s better
            • TieutieuT Online
              Tieutieu Platinum Member @zhang965
              @zhang965 Vertical precision should bring us something very good again. I don’t think it is a « willing » question, but directly impacted by hardware
                A Former User @zhang965
                @zhang965 said in Running pace vs 965:
                Have a great day
                Hello André
                Br
                The thing is that I think the 965 is more accurate than the Ambit 3, no way I was running at 4:50 hehe
                These are some comparisons that I’ve done.
                S9B vs 965 (auto gps mode)
                https://quantified-self.io/user/ryUIzJJ1nqe3AYplQMIJWy4SFBc2/event/ZjRDneWnx5wj0Rn5G2ge
                Ambit 3 vs 965 (auto gps mode)
                https://quantified-self.io/user/ryUIzJJ1nqe3AYplQMIJWy4SFBc2/event/lEBfYwK9NOoas82J81HY
                Ambit 3 (Good gps) vs 1040 solar
                https://quantified-self.io/user/ryUIzJJ1nqe3AYplQMIJWy4SFBc2/event/Ud63WRb0aL7qIim6esNU
                  zhang965 @Guest
                  Have a great day
                  Hello André
                  Br
                  much appreciated
                    MKPotts Bronze Member
                    I used an Ambit 3 Peak for about 2 years before switching to a S9B. For me, instant pace was just as realistic, stable and responsive on the S9B as the A3P. Location accuracy with the S9B was noticeably poorer in difficult conditions (tree cover etc) when I first got it - which affected pace sometimes - but now it’s more or less as good as the A3P was.
                    I used a Garmin Enduro for about 2 months, which I believe has the same Sony chip as the S9B. Instant pace was much less reliable with the Garmin - often unrealistic changes or a lack of responsiveness.
                    I always understood the calculations used to filter and average the data and how data from the other sensors is/isn’t used plays a big part with instant pace. Even if you assume the watch has a positional accuracy of 1m in good conditions, that will still give significant variability for each (1 sec) data point, especially if running more slowly. In my limited experience - comparing Garmin and Suunto watches that used the same Sony chip - Suunto was better at handling the data to give a usable instant pace.
                    I’m not sure the newer (multi-satellite and/or dual band) chips will make much difference to instant pace, at least under good signal conditions. I’ve not noticed any difference in instant pace with my S9PP compared to my S9B - both generally good and both useless on the London marathon around the 30km point, where the route weaves between high buildings.
                      zhang965 @MKPotts
                      @MKPotts said in Running pace vs 965:
                      My experience on pace stability :
                      (Ambit 3 peak ≈ Spartan race ultra ≈ early firmware s9b )
                      Better than
                      (Later firmware S9B ≈ S9P ≈ S9PP)
                      my experience on gps tracker stability :
                      Ambit 3 peak ≈ Spartan race ultra ≈ later firmware s9B ≈ S9P)
                      Better than
                      (Early firmware S9B ≈ S9PP)
                      S9PP has a bigger Standard deviation, it’s painful for me.
                        MKPotts Bronze Member @zhang965
                        @zhang965
                        What do you mean by “gps tracker stability”? How accurately the track reflects where you actually ran?
                        I’ve not seen any difference in the reliability of instant pace between A3P, S9B and S9PP. But I rarely run in areas where GNSS signal is challenging - not sure if you do?
                        Because the S9PP uses a new chip, it’s maybe not surprising you’re having problems with pace, given there hasn’t been any firmware update to optimise data processing.
                          zhang965 @MKPotts
                          @zhang965
                          For example, I run the same route in Paris ( I don’t think it’s more challenging than London)
                          If I compare the gps trackers, other watch’s Standard deviation is pretty small,
                          But s9pp has the best gps tracker and the worst, it makes me uncomfortable, but I think it can be fix by future update ( anyway I’m not waiting it anymore)
                            @zhang965
                            Understood now and my experience is similar. Most of the time my S9PP track accuracy is very good. I’ve run the London Marathon the last 3 times with S9B, S9P and S9PP and the S9PP gave the most accurate track (better than a friend got with a Fenix 7X). But occasionally the track is quite a bit poorer. Whereas S9B/P are consistently good.
                            Back to the original question about instant pace, I think this just reinforces that data processing is the key factor when it comes to variability.
                            Hopefully your Vertical will be better. I think it has the same Sony chip as the S9PP, so guess they will already have knowledge of how to optimise.
                              isazi Moderator @MKPotts
                              @MKPotts next firmware update for S9PP should include a new Sony firmware.
                              suzzloS 1 Reply Last reply Reply Quote 3
                              • suzzloS Offline
                                suzzlo Moderator @isazi
                                @isazi any idea if S9P will also be updated?
                                Garmin: FR745, Edge 530
                                SA topics:
                                • MiniForkliftM Offline
                                  MiniForklift Platinum Member @Guest
                                  …but there is one thing that during the run is not identical, is the instant PACE.
                                  This is something I also noticed when I was using my Garmin Enduro. Often while running the current pace on the Enduro is incorrect, for example I know I am running a sub 5min/km but the pace reads 6min/km. It’s odd and frustrating but as you mentioned, at the end of the run the average pace seems to be correct and all is good. When I first noticed this I actually thought I had the wrong setting as it was so far off what it should be. I don’t use that watch any more but I would be interested to know why it does that but the average pace works out to be correct in the end 😯
                                  FWIW my S9B has always been great with regards to current & average pace, but as @MKPotts alluded to mine does struggle when running in the forest/under tree cover
                                  SV Titanium Solar Forest
                                    A Former User @MiniForklift
                                    @MiniForklift said in Running pace vs 965:
                                    Except that in my case is the garmin that is correct .
                                    My intention with the thread was not discussing if one brand was more accurate than the other , was trying to understand why this happens
                                      isazi Moderator @suzzlo
                                      @suzzlo it should, but no new GPS firmware.
                                        MKPotts Bronze Member @Guest
                                        @André-Faria
                                        In my first post I mentioned the Enduro because I had experience of using it at the same time as the S9B and they use the same Sony GNSS chip (as far as I know). So the differences I saw in the reliability of instant pace (S9B much better than the Enduro) must have been caused by factors other than the chip and its firmware (written by Sony?).
                                        My assumption is that it is the use of other sensor data (accelerometer?), to compare against the location (GNSS) data, that is important (don’t Suunto call this “FusedPace” or similar?). This I believe helps the watch decide if you’ve changed pace versus noise/error in each individual (1 sec) location point. Over longer time periods, I guess these errors tend to cancel (and/or additional data processing?), hence lap or total run pace looks the same (as it did for my S9B vs Enduro).
                                        If your 965 is more accurate for pace than your Ambit, I guess that means Garmin have managed to very effectively optimise data processing with the new chip (Mediatek?).
                                        Like you, I’m also interested to learn more about how watches calculate pace, so would love to hear from someone with expertise in the area.
                                          You are probably seeing speeds ups and drops due to speeding up from static position etc. And that is fine if that is the case.
                                          The instant pace in Suunto watches (As already discussed here ) is much better than most competitors (and a reason for this discussion from prev members such as @skyrunner etc) .
                                          What you need todo in order to report a bug or put weight in the discussion is to compare FIT files on the speed chart.
                                          Notice that Suunto watches use INSTANT speed / pace not averaged (5-10s) such as for example coros and garmin etc. That is a trade off for the instant speed.
                                          Additionally with older watches than the vertical , running with left / right hand will have different paces on track and field due to the offset if the watch is not having a good signal.
                                            @Dimitrios-Kanellopoulos said in Running pace vs 965:
                                            I don’t want to point a bug or complain. Your last sentence gave me a clue, I was always with the ambit on right hand.
                                            Thank you for taking the time to answer me and better understanding how things work, which was my aim.
