    Core Bodytemperatur Sensor dont Work with Vertical
    27 Posts 10 Posters 3.2k Views 9 Watching
    • GiPFELKiNDG Online
      GiPFELKiND Silver Members
      Screenshot_2023-06-21-20-49-46-897_com.stt.android.suunto.jpg Screenshot_2023-06-21-20-49-50-307_com.stt.android.suunto.jpg Screenshot_2023-06-21-20-49-53-194_com.stt.android.suunto.jpg
      The CORE Body Temperatur sensor is not supported with the Vertical Watch. All Suunto 9 Models are supported and Show this Sensor in Suunto Sport App and on the watch! Please Integrate this Sensor for the Vertical!!!
      If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, 9 Baro, 9 Peak, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android๐Ÿƒ๐Ÿผ๐Ÿง—๐Ÿšต
      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote -2
        It is known and already discussed in the forum, Suunto and Core are working together to fix this.
          Dimitrios Kanellopoulos Community Manager @GiPFELKiND
          @GiPFELKiND please check again
          GiPFELKiNDG 2 Replies Last reply Reply Quote 1
            GiPFELKiND Silver Members @Dimitrios Kanellopoulos
            @Dimitrios-Kanellopoulos i Check it later when i am at home ๐Ÿ˜Š
            L 1 Reply Last reply Reply Quote -1
              lessthanmore Bronze Member @GiPFELKiND
              @GiPFELKiND If you did not check it again why on earth do you state in the other thread that it is still not working?
              Your posts are getting pretty annoying.
              And I cannot be the only one. Stick to one effing thread and stop spamming multiple threads with the same topic.
              My advice would be to be more constructive and less whiny.
              zhang965Z 1 Reply Last reply Reply Quote 6
                zhang965 @lessthanmore
                @lessthanmore said in Core Bodytemperatur Sensor dont Work with Vertical:
                Donโ€™t be so mean, not everyone can have many toys like you.
                L 1 Reply Last reply Reply Quote -2
                  lessthanmore Bronze Member @zhang965
                  @zhang965 said in Core Bodytemperatur Sensor dont Work with Vertical:
                  Welcome to Suunto Community.
                      @Dimitrios-Kanellopoulos checkedโ€ฆ No compatibleโ€ฆ Without a update how should it work ๐Ÿ™ˆ
                      GiPFELKiNDG EgikaE 2 Replies Last reply Reply Quote 0
                        GiPFELKiND Silver Members @GiPFELKiND
                        @GiPFELKiND Screenshot_2023-06-22-22-52-50-171_com.stt.android.suunto-edit.jpg
                          soisan @GiPFELKiND
                          @GiPFELKiND The app can now be installed, at least in my Vertical.
                            Egika Platinum Member @GiPFELKiND
                            @GiPFELKiND the S+ apps are updated in the background.
                            You need to pull on the S+ selection to have them reloaded.
                              GiPFELKiND Silver Members @Egika
                              @Egika please can you help me? i sent you message in chat with video, so you can see thats not working ๐Ÿ˜ž or i am little stupid โ€ฆ
                                @GiPFELKiND Suunto App -> Click on the watch -> S+ Apps -> Pull down to refresh
                                  GiPFELKiND Silver Members @lessthanmore
                                  @lessthanmore GOT THE PROBLEM SOLVED!!! ๐Ÿ˜Š๐Ÿ˜Š๐Ÿ˜Š๐Ÿ˜Š๐Ÿ˜Š๐Ÿ˜Š๐Ÿ˜Š๐Ÿ˜Š๐Ÿ˜Š๐Ÿ˜Š nothing you all sayed worked!!! The only Thing was to delete the suunto App and fully new installed.
                                  NOW the CORE Body Temperatur sensor is shown and worked FINE with S+ App ๐Ÿ˜Š๐Ÿ˜Š๐Ÿ˜Š๐Ÿ˜Š๐Ÿ˜Š Thanx for your HELP ๐Ÿ˜
                                  • lexterm77L Offline
                                    lexterm77 Bronze Member
                                    When you turn on active look s+ app, core one doesnโ€™t work. Decimal point needs to go one character to the right. When I get 0.1C degrees increase it shows 0.01C instead of 0.1C.
                                    Edit: this is fine, itโ€™s actually a derivative of your core temp so you know if itโ€™s increasing or decreasing.
                                    Also, please use single temperature scale so delta value can be visualized.
                                    Excess decimals in SA:
                                      trailcafe Bronze Member
                                      Internally the CoreBodyTemp is recorded in ยฐ Kelvin. Is it planned to switch it to ยฐ Celsius? When I import the FIT file into WKO I have to convert it into ยฐ Celsius if FIT file is from a Suunto watch and to keep it as it is when it comes from a Garmin watch
                                        isazi Moderator @trailcafe
                                        @trailcafe thatโ€™s interesting, I can ask.
                                        Edit: do you have two FIT files, one from Suunto and one from Garmin, to show the difference?
                                          trailcafe Bronze Member @isazi
                                          @isazi sure yes. I can send it to you but I am already in contact with some guys from CoreBodyTemp because I am testing their sensor. Maybe we should open up only one channel (via CoreBodyTemp) and not another one with the same topic, what do you think?
                                            @trailcafe if they also work on the S+ app then fine. If it is about the FIT export from SA, better to involve Suunto (as they do the conversion to FIT).
