    Suunto vertical with significant added distance for walks
    36 Posts 16 Posters 4.4k Views 14 Watching
    • leafs93L Offline
      leafs93 Bronze Member
      I have been wearing my Vertical for a couple of weeks now. I realise that it adds quite a bit of distance for walks, and sometimes for runs as well. I do wear a couple of watches while I run or walk, and this morning after my walk, the distances that show up for all my watches are:
      1. suunto Vertical - 11.72km
      2. suunto 9 peak pro - 11.55km
      3. COROS apex 2 pro- 11.41km
      4. Apple Watch series 8 - 11.42km
      By the way, there were no tall built ups and sky was clear. Walking on pavement throughout.
      I have had Baro, 9 peak, 5 peak before and all Suunto watches always added distance for my walks or run. With Vertical that has dual band, I thought the distance will be more similar to that of other dual band watches such as apex 2 pro and Garmin FR 955, but invariably the vertical always show more distance, sometimes as much as 600m for a 16km run.
      I know many of you will say what makes me think that distance on Suunto is not correct? I have run on same route for many years, and both FR 955 and Alex 2 pro always show up within less than 10 meters from each other. But for my Vertical, it is more than 300 meters from other dual band watch.
      Is there a way for me to reset the GPS on my vertical without resetting the Watch ?
      Jeffrey TillackJ zhang965Z HighlandsH ? S 5 Replies Last reply Reply Quote 1
      • Jeffrey TillackJ Offline
        Jeffrey Tillack Bronze Member @leafs93
        @leafs93 following
        Apple Watch Ultra 2
        Coros Vertix
        Suunto 9 Baro
        Garmin Instinct
        Polar M200 (retired)
        Coros Pace (retired)
          zhang965 @leafs93
          @leafs93 said in Suunto vertical with significant added distance for walks:
          No it’s impossible
          • HighlandsH Offline
            Highlands @leafs93
            @leafs93 My 9pp also gives more distance than my 7XSS.
            SV1&S9PP
            • Mff73M Online
              Mff73 @zhang965
              turning off/on the watch (or soft reset) will delete the internal AGPS file, and next sync with SuuntoApp will download a fresh one.
              It is the only thing users like us mays have access to.
              leafs93L 1 Reply Last reply Reply Quote 2
              • leafs93L Offline
                leafs93 Bronze Member @Mff73
                @Mff73 hey thanks. Let me try and see if this works!
                  A Former User @leafs93
                  Let’s say the “measured” distance of that walk is 11.5km
                  2% error is 0.23km , on my side all those devices seem to be under that margin, which I don’t think is a big margin, specially given how complex gps measurements can be and depending on algorithms.
                  But I understand zero of it. Maybe someone with full knowledge can tell something about it. But 2% error doesn’t seem something extraordinary .
                  At the time of the launch of the vertical , on the Spanish telegram group it was stated that Suunto compared with other brands and the vertical was the most exact.
                  I guess the complexity of this measure can be so much and depending on so much things that it is easy to have different measures between devices.
                  Edit: and we also have the battery life to add. Sometimes we compare with older devices and say “the older device was more precise”…ok but with what battery life?
                  leafs93L 1 Reply Last reply Reply Quote 1
                  • leafs93L Offline
                    leafs93 Bronze Member @Guest
                    @André-Faria thanks. 2% error is probably acceptable.,but if I look closely at the GPS track, on a straight pathway, my tracks are rather ziczac compared to apex 2 pro and Apple Watch. If I don’t zoom in, the tracks all look fine but zooming in the tracks probably explain where the extra distance came from . I am not entirely sure if this could be the reason though. Anyways I can definitely live with it just that I am now puzzled as to which dual band watch is the most accurate now.
                      I have no technical knowledge to answer you, which one would be the most accurate watch, what I imagine is that it would depend also on the situation used and how it is used (which arm for example).
                      When I want to compare different watches data I upload the fit files to https://quantified-self.io/, merge and then you can see a lot of data compared.Example of Ambit 3 vs 965 Hike.
                      After that you can try to understand why it varies (is it due to settings, to error, to algorythm difference, lack of calibration (in case of altitude difference).
                      Without data from the different watches on the same day and similar position I think we could be here talking all day 😃
                      leafs93L 1 Reply Last reply Reply Quote 0
                      • leafs93L Offline
                        @André-Faria hey thanks for introducing the quantified-self app!
                        My goodness, I compared the walk I had and I totally understand why my vertical added distance. The track compared to all the rest were very off, with me walking on water or on built up areas ! I must say it is the worst in terms of GPS tracking. Both apple and apex 2 pro were mostly spot on while vertical and SPP were off tracks. The added distance came mainly from the ziczac tracks for both vertical and spp while apple and apex 2 pro were a lot more in line. In fact SPP seems to be giving better tracks compared to Vertical.
                        I also compared my run today on apple , SPP and vertical. Again , the vertical seems to be most off, hitting many buildings and on water while apple tracks seem to be more correct. And SPP had much better and correct tracks compared to Vertical.
                        Anyone else with same experience ? I am on best GPS tracking for both SPP and vertical btw.
                        Kurt68K 1 Reply Last reply Reply Quote 0
                        • Kurt68K Offline
                          Kurt68 @leafs93
                          @leafs93 looks completely different on me the 9PP is not bad but by far not as good as the vertical. I’ve now done some runs and hikes with the Vertical and the Fenix ​​7X. Both watches are mostly within 10m at the distance and the tracks also look very good on both. It’s really interesting that your vertical performs so poorly.
                          • leafs93L Offline
                            leafs93 Bronze Member @Kurt68
                            @Kurt68 interesting… I would expect vertical to be similar to that of COROS apex 2 pro and FR 955 as well. perhaps I will do a reset and see if that helps. Thanks!
                              suuntastic Bronze Member @leafs93
                              @leafs93 My S9P is very precise. More accurate than Apex 2. Also on point to Strava tracking with app. No deviation. Apex 2 lags behind. Did you do a comparison with Strava iPhone app tracking parallel? I would trust Suunto most. And watches are getting better over time (SW Update for new chipsets). No need to worry.
                              Think SV distances are also most close to race distance if you look at athletes at Strava.
                              Probably no other watch gets so much love if it is about accuracy than Suunto.
                              babychaiB 1 Reply Last reply Reply Quote 0
                              • babychaiB Offline
                                babychai Silver Members @suuntastic
                                @suuntastic It’s great that your S9P is accurate. but accuracy is depend on whether our place got trees, buildings and other factor blocking GPS signal or not.
                                my S9P and SV are normally within 500 meter difference in open area when i running in a city but my S9P can go up to 10 km difference when i hike inside tropical rainforest. i can say that S9P accuracy is not reliable when i hike inside thick forest.
                                so far my SV usually are higher than my friend who wear Coros Vertix 1 but usually within 300 meter distance difference when we hike together inside thick tropical rainforest.
                                Suunto 9 Peak All Black
                                zhang965Z gone troppoG 2 Replies Last reply Reply Quote 0
                                  zhang965 @babychai
                                  @babychai said in Suunto vertical with significant added distance for walks:
                                  10km?
                                  • gone troppoG Offline
                                    gone troppo Bronze Member @babychai
                                    @babychai
                                    Tropical rainforest is the most difficulty environment for gps I have posted about this a few times where I live. Dual band on the vertical has certainly been a revelation for me under tropical rainforest certainly a step ahead of anything up to this point. If using less than dual band you can certainly get some wild tracks and distance under rainforest canopy especially in heavy rain
                                    • babychaiB Offline
                                      babychai Silver Members @gone troppo
                                      @gone-troppo
                                      yes i read what you posted previously. we’re almost the same case.
                                      i do a lot hiking activity in tropical rainforest in my country Malaysia and do a lot breadcrumb navigation previously and now map navagation with my SV.
                                      SV distance accuracy are very impressive now inside tropical rainforest compared to previous Suunto model.
                                      • babychaiB Offline
                                        babychai Silver Members @zhang965
                                        @zhang965 Yes
                                        https://quantified-self.io/user/1jjTdg1SCcccICOf36HVUGB3JTK2/event/06Z1eCAp3MNVsFls7po4
                                          A Former User @babychai
                                          @zhang965 Yes
                                          If you use your phone and compare with both watches which one is correct? With that difference I would send one to warranty (if still possible)
                                          • babychaiB Offline
                                            babychai Silver Members @Guest
                                            @André-Faria what did you mean by phone? I did not record my activity with phone.
                                            i would say S9P’s GPS accuracy is still great except hiking under tropical rainforest especially during long hour activity. distance is even worst if i got stop and rest at the waterfall area. i guess waterfall is one of the factor affected the accuracy as well.
                                            i did running in a city/residential area and trail running the distance difference is not much compared to SV.
