    Suunto 9 Baro middle button problem
    suunto 9 baro
    4 Posts 4 Posters 1.4k Views 3 Watching
    • Mattias AlmM Offline
      Mattias Alm
      Re: Problem Activity start button
      Hello!
      I am having the same problem as in the referenced thread: sometimes the activity does not start with the middle button, instead the screen goes back to the previous one (select sport). I am pretty sure that it is not a hardware issue, at least doesn’t the button feel coarse or get stuck.
      This was especially irritating when I was starting a roller ski race a some week back; you cannot use the touch screen to initiate the session, but after a minute with frantic pressing it did start.
      Regards,
      Mattias
      inkognitoI surfboomerangS 2 Replies Last reply Reply Quote 1
      • inkognitoI Offline
        inkognito Platinum Member @Mattias Alm
        @Mattias-Alm Well, short press starts the exercise while slightly longer press (1 second) goes back… It might get slightly stuck without you noticing as 1 second is still quite short time…
        SV: fingers crossed :D
          surfboomerang @Mattias Alm
          @Mattias-Alm Rinse it with warm water. Maybe that will do the trick.
          • MdzOttM Online
            MdzOtt
            Got the same problem. It is intermittent (worse when cold). But, it is possible to operate the watch with touch. So, this is certainly not a s/w problem. You can swipe left to select the activity and i think i managed to start it with just pressing on the screen.
            Still a question: does washing it help?
            S9 Baro
            SA on Android
            Ambit 3 Peak
            Ambit 2 Sapphire
