    Suunto Wing won't charge
    Scheduled Pinned Locked Moved Headphones
    21 Posts 7 Posters 3.0k Views 7 Watching
    • Marius Jacobsen EggerudM Offline
      Marius Jacobsen Eggerud Silver Members
      Hi!
      My Suunto Wing won’t charge using the powerbank. Everything seems fine when I connect them, but when the lights on the powerbank turn off they turn off on the headphones too, and charging stops.
      Any ideas?
      Suunto Ambit 3
      Suunto Spartan Ultra
      Suunto Race Ti
      Brad_OlwinB EzioAuditoreE 2 Replies Last reply Reply Quote 0
        Brad_Olwin Moderator @Marius Jacobsen Eggerud
        @Marius-Jacobsen-Eggerud I had the same problem. Contacted support and received a replacement. Was a detective unit.
        Marius Jacobsen EggerudM 1 Reply Last reply Reply Quote 0
          Marius Jacobsen Eggerud Silver Members @Brad_Olwin
          @Brad_Olwin ok, thanks. Will reach out to support on Monday
          Suunto Ambit 3
          Suunto Race Ti
          • stromdiddilyS Offline
            stromdiddily Gold Members
            @Brad_Olwin @isazi hoping for some help here.
            I have the same problem and tried to file a warranty claim, only for it to be rejected with the note that there is already an active claim for my ID…which I have no idea how that’s possible.
            Can someone please confirm where the number is for the wing? The support website only shows watches.
              Tieutieu Platinum Member
              Are you all sure that when the lights of the bank turns off the wing don’t continue to charge ? That’s the behaviour I have with mine. Lights of the powerbank and the wing are on at the beginning of charge, and the. turn off after few sec/min. But it charges.
                stromdiddily Gold Members @Tieutieu
                @Tieutieu said in Suunto Wing won't charge:
                Quite sure…I get no change in the battery on my wings. The only time the powerbank works is if I have it plugged in.
                  Mff73
                  i don’t know the “wings” but some powerbanks are stopping to deliver current when it becomes below a certain threshhold. If wings are not needed that much current to be charged, it could be part of the explanation (or not 😉 )
                  • AudaxjoeA Offline
                    Audaxjoe
                    I also have no experience of the Wings, but know through experience some power banks don’t work with some items. I have a bike light that will not charge from one power bank but charges fine from another make (Anker)
                    It could be worth trying another power bank.
                    Suunto 9 BARO
                    Garmin Fenix 3, 5
                    Suunto Vector
                      Brad_Olwin Moderator @stromdiddily
                      @stromdiddily I had the same issue of power bank failure. I went into the website and filed a warranty claim, that allowed me to select the wing. There is a serial number you can find on the app. If you have done this and are getting the error, we can try to figure out how to alert someone at Suunto. Neither @isazi nor I have connections with service. The chat with support might help you
                        @Brad_Olwin said in Suunto Wing won't charge:
                        Oh app is a good call. I will try to get the number from there.
                        Thanks Brad!
                        • EzioAuditoreE Offline
                          EzioAuditore Gold Members @Marius Jacobsen Eggerud
                          @Marius-Jacobsen-Eggerud same thing just happened on my wings. They die after 1h of running with 60 volume no less and normal mode (headshake enabled).
                          Put them on the battery pack the leds go off put them on charger they never turn off the leds.
                            Marius Jacobsen Eggerud Silver Members @EzioAuditore
                            @EzioAuditore Reach out to Suunto. They replaced mine.
                            Suunto Ambit 3
                            Suunto Race Ti
                              @Marius-Jacobsen-Eggerud will do tomorrow. Did you send both the battery pack and the headphones? Thanks a lot,
                                @EzioAuditore yes, sent everything
                                Suunto Ambit 3
                                Suunto Race Ti
                                  @Marius-Jacobsen-Eggerud Thank you.
                                    EzioAuditore Gold Members @EzioAuditore
                                    Got my replacement. Too bad I didn’t try charging it since it was charged to 98% so I started running. Today before long run in the morning I put it in the power bank to charge and the leds were on-cool I said it’s charging. After 2-3h the leds were still on so i said ok I’ll run my 3h run and see the level afterward. It turns out the replacement is not charging at all so I cannot turn them on anymore and only the leds are on 😞
                                      stromdiddily Gold Members @EzioAuditore
                                      @EzioAuditore said in Suunto Wing won't charge:
                                      That’s pretty crap luck! I got my replacements back and so far they’re working like a charm. When it works, the power bank is a serious game changer compared to aftershokz or other competitor options
                                        EzioAuditore Gold Members @stromdiddily
                                        @stromdiddily yes I have terrible luck with both Wings and Vertical. Race and Ocean are great though (except of some minor SW related glitches). Will contact support again.
                                        UPDATE: I hate how incompetent the ppl from support are. Me: My wing are not turning on and do not work. They: I will personally handle this, bla, bla.
                                        after some minutes.
                                        They: Is there anything I can help you with, otherwise wish you nice day.
                                        Me: My problem was not resolved so what else will you help me with if you didn’t with the initial problem?
                                          after some minutes.
                                          That chat interface on Suunto’s website is absolutely horrendous
                                            Tieutieu Platinum Member @stromdiddily
                                            Bad luck indeed…my wings are working awesomely well since beginning and I really love them for training.
                                            About support chat, I used it last summer before sending my SV for repair. It took a while to have someone available on chat, but when he was ON, everything went well.
