    Sussen issues Vertical
    9 Posts 4 Posters 762 Views 4 Watching
    • Lian71L Offline
      Lian71
      Since yesterday suddenly out of the blue hassle with my Vertical. In 1 evening over Christmas dinner, my battery level dropped from 70% to 14%. Normally it consumes a few % per day!
      During charging it keeps giving incredibly irritating alarms, charging also stalls occasionally. Tried cleaning the contact points, but nothing helped.
      Tried soft reset, doesnโ€™t solve anything. The new version was installed a while back and worked fine until yesterday.
      Anyone have any idea what could be going on?
      vjakubV Lian71L 2 Replies Last reply Reply Quote 0
      • vjakubV Offline
        vjakub @Lian71
        @Lian71 I read a story of some other Vertical user having the same issue with sudden battery drain after the update.
        He solved it by charging to 100% and then using to below 10%. After next full charge everything was good.
          Battery probably need to re-calibrate
          SVTS - 2.48.16
          Suunto App Android 6.4.7 beta
          • GiPFELKiNDG Online
            GiPFELKiND Silver Members @sartoric
            @sartoric good Morning and merry Christmas ๐ŸŽ„๐Ÿ’ซ Can you please say how we calibrate the battery in Vertical? Thank you for that ๐Ÿ‘
            If it doesn't challenge you, it doesn't change you. #lifewithasthma #runwithasthma #nevergiveup #pushinglimits #adventurestartshere Suunto Ambit 3 Peak , D9, 9 Baro, 9 Peak, Vertical Ti, Race , RaceS Courtney, Race 2, Vertical 2, SA (Beta) Android๐Ÿƒ๐Ÿผ๐Ÿง—๐Ÿšต
              As explained several time, also in vjakub post.
              โ€œfullโ€ discharge and recharge
              SVTS - 2.48.16
                @sartoric said in Sussen issues Vertical:
                Sorry for asking again but this is the reason why you dislike my question with -1 ๐Ÿ˜‚๐Ÿ˜œ
                  sartoric Moderator @GiPFELKiND
                  @GiPFELKiND
                  It wasnโ€™t me, I very rarely downvote.
                  SVTS - 2.48.16
                  GiPFELKiNDG 1 Reply Last reply Reply Quote -1
                    @sartoric ๐Ÿค— okay
                    • Lian71L Offline
                      Lian71 @Lian71
                      @Lian71 said in Sussen issues Vertical:
                      Thanks everybody! Did a hard reset and the problem is solved!
