    Suunto race offline map recently work but not it's blank
    6 Posts 4 Posters 498 Views 5 Watching
    • N Offline
      Nicklasblom
      Hi! My race have a problem with just showing the mapp with no roads etc. The offline map I currently use that work before are. Sweden - västra Götaland regionen.
      If I start a run and end it it seem to know where I am. It places me right on the run afterwards on the app.
      Things I have tried.
      Remove and reinstall maps.
      Normal restart
      Soft restart
      Factory reset. And also tried a normal snart after reinstalling the map again.
        Torium @Nicklasblom
        I have the same issue (also Sweden västra Götaland). The map is only showing the height lines, as if the map is not installed on the watch.
        isaziI Stefano M64S 2 Replies Last reply Reply Quote 1
          isazi Moderator @Torium
          @Torium I am reporting it to Suunto
          • Stefano M64S Online
            Stefano M64 Silver Members @Torium
            @Torium H
            Hi, have you tried to check how that map looks on the Suunto app?
            cheers, S.
              Torium @Stefano M64
              @SteM64 Yes on the map everything is normal. Earlier this week i traveled to a couple other regions, and the map in those areas looked as they should.
                @Torium It had been solved, but you need to download the map again on the watch.
