    Interval training : no more sound nor vibration
    8 Posts 6 Posters 1.1k Views 5 Watching
      treizeXiii
      I noticed today that my watch doesn’t beep/vibrate anymore once a interval is finished. It used to sound and vibrate after every stage.
      Is it a bug, or did I change a setting without knowing (I can not fin this specific setting…).
      Thank you
      Regards,
      Yan
        Tieutieu Platinum Member @treizeXiii
        @treizeXiii have you checked if you didn’t accidentaly activated Do Not Disturb mode ?
        David lD 1 Reply Last reply Reply Quote 0
          treizeXiii
          Thank you for your proposition, and crap, I think it might be it… 😉
          I’ll check tomorrow.
          Thank you !
          Sergei LadeishchikovS 1 Reply Last reply Reply Quote 1
          • Sergei LadeishchikovS Online
            Sergei Ladeishchikov Bronze Member @treizeXiii
            @treizeXiii Hi, what was the battery level during training?
            • David lD Offline
              David l @Tieutieu
              @Tieutieu said in Interval training : no more sound nor vibration:
              It’s a bit poor if that’s the issue - they should be completely separate entities.
                A Former User @David l
                @David-l Suunto implemented DND more as a “power save mode”.
                • David lD Offline
                  David l @Guest
                  @twekkel said in Interval training : no more sound nor vibration:
                  Yes, so should be completely separate entities from using it during exercise.
                    Mattg576 @David l
                    @David-l
                    I have my Race in DND all the time as I’m not interested in mobile notifications, it improves battery life massively & only takes a quick button press to wake up the watch to see the time (it continues to monitor 24hr HR/HRV).
                    I’ve found that if I wake up the watch with a button press & start an activity (DND still enabled in the background) the Race tracks the activity, gives HR zones/map etc & everything works perfectly BUT doesn’t vibrate even though its turned on.
                    I have to disable DND before starting the activity & then it vibrates as it should.
                    Took me a while to work this out as I’ve just started using the race nutrition app & kept missing the reminders.
                    Race
                    9 Peak
                    Ambit 3 Peak
                    Ambit 2R (sold)
                    Suunto T3d (expired)
