    Suunto 9 Peak Pro - battery life
    4 Posts 2 Posters 656 Views 1 Watching
      EDUSP
      Hi, for the Suunto 9 Peak Pro, I am trying to configure the same functionality as on the Ambit 3 Peak. When the phone is not moved, the screen is turned off after a period. The battery lasts very little, one-two weeks.
      Is there a particular configuration with which it can reach the specified values?
      BATTERY LIFE:
      In time mode 30 days
      With 24/7 tracking and mobile notifications 21 days
      I am currently on this configuration:
      Brightness > Low
      Standby > On
      Raise to wake up > Low
      Notifications > Off
      Thank you in advance!
      • isaziI isazi moved this topic from Sports Tracker on
        A Former User @EDUSP
        @EDUSP said in Suunto 9 Peak Pro - battery life:
        Standby > On
        It’s a battery hungry option imo
        When the watch is idle screen should go to sleep but the bug is still there, so next round.
        E 1 Reply Last reply Reply Quote 3
          EDUSP @Guest
          @cjanevate said in Suunto 9 Peak Pro - battery life:
          Standby > On
          I understand, I disable the function and that way I will have a longer duration.
          Standby > Off
          Raise to wake up > Off
          The curious thing is that I caught him several times with the screen off. How, I don’t know. With the settings written in the initial post.
          Is there a time after which the screen turns off completely in case the clock does not move? I’m not referring to “dims after one minute of inactivity”.
          I noticed that it doesn’t have Button lock>Time mode lock …
            Yes, sometimes it works (i.e. the screen goes black) but it is a random event. The timeout [fixed] is a few minutes.
