    Charging and Battery Care
    9 Posts 7 Posters 2.4k Views 7 Watching
    • Stefano M64S Online
      Stefano M64 Silver Members
      Hi, someone knows if there is some technical recommendation concerning the battery charging of our Suunto watches?
      I know that for Li-ion batteries it is usually advised to keep the charge level between 50% to 80%-90%, when possible, that is:
      • avoid to drain it too much below 50% (too often)
      • recharge it at 90%, or even better to 80%.
        Taking this care should extend the battery life. For example, my Sony Xperia smartphone has a built-in function that optionally can stop the recharging at 80% or 90%.
        According to that, I decided to not fully charge my Race, as I see that it reaches a level >90% I remove it from the charger. In any case, I believe it is “not wise” to keep it charging when it has already reached 99%.
      AudaxjoeA freeheelerF 2 Replies Last reply Reply Quote 1
      • AudaxjoeA Offline
        Audaxjoe @Stefano M64
        @SteM64 I never bother with any tactics to charging. My Suunto 9b battery was as strong after six years as the day purchased.
        I’d certainly not think too much about it.
        Suunto 9 BARO
        Garmin Fenix 3, 5
        Suunto Vector
        pilleusP 1 Reply Last reply Reply Quote 2
        • Łukasz SzmigielŁ Offline
          Łukasz Szmigiel
          I assume that if there were significant benefits on doing so, a battery care mode would be implemented in our watches. I think that the technology is mature enough that it’s no longer necessary to manually charge between certain amounts. Also, notice that modern Suunto watches (those that have quick charge) slow down charging significantly after reaching 80%
          S9PP 2.50.28
            freeheeler @Stefano M64
            @SteM64
            what @Łukasz-Szmigiel says
            additionally: bear in mind that we charge our phones slightly more often than the watches. battery wear also depends on the amount of cycles
            Mff73M 1 Reply Last reply Reply Quote 4
            • pilleusP Offline
              pilleus @Audaxjoe
              @Audaxjoe said in Charging and Battery Care:
              After all these years and countless charging processes, my old Spartan Ultra has no problem with the battery. 👍
              Of course, it may be a different type of battery …
              Suunto Vertical Black Lime
              Suunto 9 Peak Pro Black
                Mff73 @freeheeler
                @freeheeler said in Charging and Battery Care:
                @SteM64
                i am really not any expert, but :
                1- i think yes, Li-ion batteries lifetime “could” be enhanced with some care, but does it worth the effort ?
                2- but i also think that lifetime is linked to full charge number of cycles
                phones are globally charged everyday (big picture average), while our watches, let’s assume each week (for the sake of calculation)
                Let’s assume 1000 cycles of charge acceptable -->
                phone battery can be in acceptable shape for something like 3 years (1000/365 days)
                while watch may still be acceptable shape for 7x more --> 21 years
                if my calculation is reflecting something real, i would prefer not to care about charging my watch when i want and/or when i need 🙂
                SSU (retired), SV1, SV2
                Android + Galaxy S205G
                freeheelerF TieutieuT 2 Replies Last reply Reply Quote 2
                  yes, all your observations are correct, don’t need to care much about charging!
                    freeheeler @Mff73
                    @Mff73
                    I wish we’ve had updates for 21 years 😁
                      Tieutieu Platinum Member @Mff73
                      @Mff73 Also, considering that battery duration has considerably been enhanced with last generation of watches (S9pp < SR < SV), the number of charge cycles his more than divided by 2 compared to previous generations.
                      Suunto Wing & Spark
