    Cardio Belt not working anymore
    7 Posts 5 Posters 431 Views 5 Watching
    • Paolo GrinzatoP Offline
      Paolo Grinzato
      Since update 2.33.14, no way to use the cardio belt. It does pair with S9PP but no recording beats.
      It happens with two different S9PP and three different belts and sensor.
      Anyone experiencing the same?
      Thanks.
      Brad_OlwinB ? Ivan De RasisI 4 Replies Last reply Reply Quote 0
        Brad_Olwin Moderator @Paolo Grinzato
        @Paolo-Grinzato What belt?. My Suunto belt works perfectly.
        Paolo GrinzatoP 1 Reply Last reply Reply Quote 0
          Paolo Grinzato @Brad_Olwin
          @Brad_Olwin two suunto and one wahoo.
          But none wokrs
            Mff73 @Paolo Grinzato
            @Paolo-Grinzato
            Did you check the obvious settings, like HR sensor enabled in your sportsmode, or battery setting not in Ultra mode?
              A Former User @Paolo Grinzato
              @Paolo-Grinzato no issues here (S9PP + Bryton belt).
              Can the belt be connected to a phone for example?
              • Ivan De RasisI Offline
                Ivan De Rasis @Paolo Grinzato
                @Paolo-Grinzato Ho riscontrato che durante gli allenamenti la fascia cardio mi registra picchi elevatissimi anche quando lavoro a bassa frequenza … problema rilevato sia con fascia polar e sia con fascia Suunto
                Suunto 9 Baro
                  @Paolo-Grinzato Have you tried a soft reset?
