    Suunto Race S general discussion
    439 Posts 122 Posters 92.5k Views 104 Watching
      szleslie Bronze Member @Tieutieu
      @Tieutieu OK. I believe. I will order one and try it.
        isazi Moderator @Tieutieu
        @Tieutieu oh good, this is new, always worked for me on Android but didn’t work on iOS in the past
          Tieutieu Platinum Member @isazi
          @isazi it as always worked for me on iOS as far as I can remember, on my sv and after that on my SRs, since beginning it was released
            defencee
            Can anybody show, please, how looks “Strength Exercises” from Suunto Plus.
            And when will a full-fledged strength training designer with exercises be expected?
              Egika Platinum Member @Tieutieu
              @Tieutieu correct.
              It has been working with iOS for years.
              The difference to Android is, that syncing routes from the phone needs an active internet connection with iOS.
                Tieutieu Platinum Member @Egika
                @Egika oh yes I forgot to mention that !
                  I ordered a Race S Titanium to try it out. It is in my hand. Firmware 2.43.12, App 2.46.3. I am on iOS 18.5 with an iPhone 13 Pro Max. I will test it to see which one to keep (Epix gen 2 Sapphire or Suunto Race S).
                  Route sync works fine. I started an exercise with navigation using a route on the watch. Then uploaded a new route to the watch while it was recording the activity. Selected a new route without any issue. It works. Thx for your help!
                  (Just a side note. I am not interested any metric any more. I use my Epix for timekeeping/wake up alarm/countdown timer/activity recorder (heart rate strap+cycling power meter to control my load no training in the future, maybe I will do some but to do that I will need a computer.) and navigation. That map render, rotate, zoom in/out is much quicker and smoother. I ordered one at release but sent it back because it was so different from Garmin. I will test it and decide which one to keep. I hope this Race S will not be worse than the Epix regarding software stability. There is an other option, Amazfit T-Rex 3. I had it for some days at release. Sent it back for a same reason as Race S. Time will tell.)
                    Tieutieu Platinum Member @szleslie
                    @szleslie using SRs since release last year, never had any issue
                      I did a route import test without internet connection. I am sad about the results (maybe I missed something). I knew that Suunto app can not create a route in offline mode. It is not a problem since Osmand and the recommended Mapout does the job. But, and it is a huge but, the Suunto app can not import the route in offline mode. It says No internet connection. I tried to share from Mapout directly to the Suunto app and as a second option import from saved file with no luck. Is there a method to do this? What if there is no cell coverage and I need to create a route? Garmin is almost the same. With no internet Garmin Connect app can not receive a new route. I had to download the Garmin Explore app to import a new route. It has a limitation because it handles the imported file as a course. It said it will be decrease the points of the imported route. It was a 600 meter long route and after the import it become worse than the original and there is no turn by turn. Garmin explore can create a route but the map has less details, paths are missing. I tried the Amazfit Zepp app (I do not have any watch from them at the moment) and it worked without any issues. It imported the route and there was a send to device button. I am not part of a South Pole expedition where there is no cell coverage only sat comm but it would be nice if it would work offline. It was two weeks ago when I needed to create new routes to my Garmin Epix during my hike two times. I was lucky there was cell coverage. What if there is no internet connection. On Garmin I can use the watch to create routes but it is not convenient at all.
                        szleslie Bronze Member @szleslie
                        @szleslie It seems to me when I try to import/share a route to Suunto/Garmin/Zepp/Bryton app they need an internet connection to do something with the gpx on their servers and load it back to the app then to the device. Only the Zepp app seems to accept the import but I do not have a device with me I am not sure about the result on the watch. When offline the import is not possible except the Zepp but in the app the imported route has less points than the original gpx and cut corners and not follows roads perfectly. I uploaded the Mapout crated gpx file to two different gpx visualiser page. The track follows the roads or paths fine. When the garmin watch create a route itself the result is perfect as well. So it is not a watch limit.
                          far-blue Bronze Member @Tieutieu
                          @Tieutieu @szleslie @isazi Updating a route while in an activity worked well for me yesterday. I’d created a komoot route for my workout and started the activity etc. only to realise turn-by-turn was enabled and I really didn’t want it. So I pulled up the control panel, set the navigation to ‘off’ then, leaving the watch in the control panel (and while still running, I might add), opened up the SA, turned off turn-by-turn for the route and waited for it to sync. Then I changed navigation on the watch back to the route I wanted and exited the control panel and everything worked perfectly. I only switched navigation to ‘off’ due to the comment @szleslie made about editing an active route crashing the watch 🙂
                          First time I’ve tried this, thanks to this discussion! In the past I would have assumed I’d need to stop the activity because normal sync of the watch won’t work when anywhere other than the ‘home’ screen.
                          Thanks for the tip and more people should know about this hugely useful feature!
                            Mff73 @szleslie
                            @szleslie
                            Just tested with Android, and it works like a charm.
                            Locusmap offline gpx generation. Share to SuuntoApp, and zou, all offline.
                            Tried the same “in activity”, works also.
                              szleslie Bronze Member @Mff73
                              @Mff73 I can confirm. Offline route import is working on Android. I tried it on my old backup phone. (Garmin Connect can not import a gpx in offline on Android). Why is it so? Is it an iOS limitation?
                                @szleslie I asked support. The main reason is iOS System Permissions and Design Limitations and Differences Between Android and iOS Platforms. Android is more flexible.
                                  tomtom73
                                  Is there a way to display NGP in the watch without having the climb app ?
                                  I like it but I don’t want the auto laps generated by climb when racing, I prefer to do laps at aid station or specific points.
                                  Thanks !
                                    Mff73 @tomtom73
                                    @tomtom73 ZoneSense app can display it
                                      Marc-suunto
                                      Got my Race S just a couple of months ago, very pleased with it.
                                      Finally got my screens as i wanted them.
                                      Last night however my watch had a spontaneous factory reset, and i lost all my settings, not very amused.
                                      Maybe it has to do with an update.
                                      Is there anyone else with this issue, and is there a way that i could have prevented this? Or is there a way to backup and restore my settings?
                                      Tami999T 1 Reply Last reply Reply Quote 1
                                      • Tami999T Offline
                                        Tami999 Silver Members @Marc-suunto
                                        @Marc-suunto said in Suunto Race S general discussion:
                                        Watch could download update automatically from Your app but as far as I know (I got Race, previously Vertical) It wont DO update automatically.
                                        M 1 Reply Last reply Reply Quote -1
                                          Marc-suunto @Tami999
                                          When i went to sleep, everything was fine.
                                          When i woke up, and wanted to put my Race S on my wrist (i don’t sleep with my watch), I needed to select the language, let the watch know my weight and length and needed to make a new connection with the Suunto app. Could still see my old Spartan in the app.
                                          I do not let Android automatically update my apps.
                                          Pixel 7, Android 16
                                          Suunto app: 5.3.7 (5003007)
                                          Current software watch: 2.44.46
