    Issue - morning report
    13 Posts 5 Posters 1.6k Views 6 Watching
    • dreamer_D Online
      dreamer_
      I have seen several times when I wake up at night to go to the bathroom or just to see the time that if I press a button, the morning report is presented even if I have the DND mode enabled. That screen should not be there until the end of the DND. It does not make sense to have that screen enabled at 4am saying that you have slept only 4 hours
      Suunto Vertical 2 Titanium Sage, Suunto Run
        Tieutieu Platinum Member @dreamer_
        @dreamer_ When I wake up at night (i also have DND mode ON), My SV gives me the morning report (same behaviours that you noticed).
        If I go to bed again, when I wake I get the news report with total sleep and time awake. It’s perfectly accurate.
        If I have been waking up for a race for instance that was starting at night, the initial report even if DND is ON, is then perfecly ok.
        So for me behaviour seems pretty accurate and pertinent (also considering that DND mode mostly deactivate sounds, and lower the backlight - it’s not a “all functions of the watch are OFF” mode).
        Suunto Wing & Spark
        dreamer_D 1 Reply Last reply Reply Quote 7
          duffman19
          Exactly what @Tieutieu said. Most other watch brands (I know Garmin and Apple for sure) will not continue to track sleep once you’ve viewed the morning report. Suunto does.
          For instance, this morning I woke when the watch’s alarm went off (the same time the DND was set to turn off as well). I viewed the morning report, got up for a few minutes and decided I could use more sleep. I turned DND back on, went back to bed for a bit, and received a new morning report with updated sleep times when I awoke a second time. That’s ideal.
          Again as @Tieutieu mentioned, sometimes you do need to get up at 4am!
          • dreamer_D Online
            dreamer_ @Tieutieu
            @Tieutieu thanks a lot. I didn’t know that.
            But why are we supposed to have that screen on when you have DND enabled? I mean, It does not make any sense to have that screen flashed at night just because you have pressed a button.
              duffman19 @dreamer_
              @dreamer_ I don’t think DND and sleep are exclusively linked. DND simply mutes sounds and vibrations and dims the screen. It can be turned on and off any time, like when in a theater. This is why there are separate Sleep and DND schedules. The watch is using your Sleep schedule to more closely monitor when you fall asleep and wake using HR, movement, etc. The DND schedule is just a handy way to turn off notifications without having to activate it every night.
              For me, I have the Sleep schedule extended beyond when I usually go to sleep and wake so it is more likely to catch times I drift off early or sleep in late. My DND schedule is more narrow (ends earlier than Sleep) so that I don’t miss important notifications or phone calls that might come early in the morning.
              So in the scenario where you do need to wake early (4am for a race), you’ll need to remember to turn DND off if you want to receive notifications.
              dreamer_D 1 Reply Last reply Reply Quote 5
              • dreamer_D Online
                dreamer_ @duffman19
                @duffman19 nice point. I usually have all notifications disabled (in any watch) because I don’t like the idea of having pop-ups in my watch everytime. We are so connected that I have enough with the notifications in the phone 😁. This is something totally personal, of course 😉
                About the morning report, I don’t find myself this like a big issue, of course. But is more likely you are going to wake up after or near the end of your DND; and not everyday at 4am or whatever.
                I mean, if you have set the DND is because it’s very likely you don’t want that morning report notification at any time in the night.
                dreamer_D 1 Reply Last reply Reply Quote 1
                • dreamer_D Online
                  dreamer_ @dreamer_
                  Today I have not received the morning report after the update.
                  Has anyone else not received the report?
                  ? Brad_OlwinB 2 Replies Last reply Reply Quote 0
                    A Former User @dreamer_
                    • dreamer_D Online
                      dreamer_ @Guest
                      @Todd-Danielczyk I meant, I did not received the report in the watch today. As I was posting in the other thread, It is there in the app though
                        Brad_Olwin Moderator @dreamer_
                        @dreamer_ I had this occur once. You might do a restart of the watch.
                        Vector/T6c/Vertical 2 Ti
                        dreamer_D 2 Replies Last reply Reply Quote 1
                        • dreamer_D Online
                          dreamer_ @Brad_Olwin
                          @Brad_Olwin thanks! Restarted!. 😉
                          • dreamer_D Online
                            @Brad_Olwin today it is there!. Thanks!!
                              @dreamer_ 👏
