    FusedTrack works great - for 16 Minutes or 2,5km
    31 Posts 5 Posters 1.8k Views 5 Watching
    • VoiGASV Offline
      VoiGAS Silver Members @isazi
      @isazi How can you see it was not it performance mode? Is this maybe something I can analyze for my own runs? I just tried it with the GPX (Workout) Export and like expected it is showing 1-3 second intervalls for the first 17 (strange, really 17 and not 15) minutes and afterwards just one position entry per minute
      Edit I mean the old, faulty one. After the reset I still have to try
        isazi Moderator @VoiGAS
        @VoiGAS because the track would be much better if it was in performance mode.
        • VoiGASV Offline
          Soft Reset did not work, same 1 Minute Jumps like before ☹️. Worst thing is that it completly cuts the last meters that way. If it would just sync GPS at the end.
          Next station Hard Reset, I hope it helps
          • VoiGASV Offline
            Update after Hard Reset: At the end of the Calibration (Performance Mode) Run the watch showed a message “Laufen kalibriert” (running calibrated). This message didn’t show up after the soft reset, so I keep my fingers crossed for tomorrow…
            • VoiGASV Offline
              @isazi @Łukasz-Szmigiel Unfortunatly it didn’t work. I also noticed that the pace was way off, it showed 7:00 to 11:00min/km during the run. So also FusedSpeed doesn’t work. Thats really a bummer as the Fused Algorithms are Suuntos USP and I really like to use them.
              I guess the accelerometer is defective - hopefully Suunto can repair it ☹️
              • VoiGASV Offline
                Update after I sent the watch to Suunto for repair: No defect, I should try to do a calibration run and the watch is already on the way home 😤
                Somehow I expected it to be this way, but still I’m disappointed. I like Suuntos idea with FusedTrack, but I think it should also work…
                • VoiGASV Offline
                  Also after the supports actions it doesn’t work. My theory is that FusedTrack doesn’t exist anymore, at least not on S9 Peak https://forum.suunto.com/post/149960
                  So this thread can be closed
                    Brad_Olwin Moderator @VoiGAS
                    @VoiGAS said in FusedTrack works great - for 16 Minutes or 2,5km:
                    I checked an old manual I have against a new one, you are correct. I will test this by tomorrow. I have my 9Peak and Suunto 9baro charging to see if both behave the same way. I’ll report back here for you.
                    VoiGASV 1 Reply Last reply Reply Quote 2
                    • VoiGASV Offline
                      VoiGAS Silver Members @Brad_Olwin
                      @Brad_Olwin How did it go? Great that you have such an impression Suunto collection for comparsions 😀
                        Sorry, will do soon. Fires near required us to prepare for a potential evacuation. Better now so hopefully test this tomorrow or over the weekend.
                        • VoiGASV Offline
                          @Brad_Olwin Oh no! All the best for you and sorry to bother you with such a thing
