    Threadmill running distance not recorded
    3 Posts 2 Posters 482 Views 2 Watching
    • C Offline
      cleoleeps
      My 9PP used to be able to record how long the distance I’ve run when I used threadmill. But it didn’t capture properly since Jun 2024. The GPS is already turned on and off for threadmill mode but doesn’t help.
      I should be running like 3-4 km after 30 mins but it recorded like less than 1km.
      What is missing ?
      • C Offline
        cleoleeps
        Is there anyone having this issue too ?
        • EgikaE Online
          Egika Platinum Member
          the treadmill distance is calibrated from outdoor runs with GPS.
          The watch matches your individual arm movement to the GPS data and uses this for indoor running.
          Try an outdoor run to get the calibration.
          Then: After running on the treadmill you can manually adjust the real distance reported by the treadmill in the activity summary screen on the watch, if you want
          • EgikaE Egika referenced this topic on
