    Offline Map not showing
    7 Posts 3 Posters 508 Views 2 Watching
      beni.m
      on my Suunto Race I use the ofline maps for navigation. Quite often, the map does not load while navigation. The black screen with white lines appears as background.
      The Maps are completely downloaded onto the watch.
      Thx for any advice how to fix this!
      DesdinovaD ? 2 Replies Last reply Reply Quote 0
      • DesdinovaD Offline
        Desdinova Bronze Member @beni.m
        @beni-m First thoughts would be check you;re not on the boundary of a map region, and in the activity try toggling the maps off and on?
          A Former User @beni.m
          @beni-m do you have the exact coordinates available? @pavel.samokha has been very helpful (and fast!) in resolving this kind of map issues in the past.
            beni.m @Desdinova
            @Desdinova no. I‘m navigating in the center os the map. At least 50k to the border
              beni.m @Guest
              @twekkel Yes. The position coordinates are correct. Also the blue track draws correctly. Sometimes the map appears when I choose a different zoom level. I think it is an issue of the watch‘s micro processor.
              DesdinovaD 2 Replies Last reply Reply Quote 0
                @beni-m more likely some data didn’t download properly. Try uninstalling the relevant map and reinstall?
                  @beni-m try following this
                  https://forum.suunto.com/topic/11406/low-zoom-level-1-km-not-available-in-norway
