    Skip lap button not working in workouts with Custom Sports Mode
    13 Posts 5 Posters 929 Views 5 Watching
    • Genis MajoralG Offline
      Genis Majoral
      I saw this issue in other posts so it is persisting over time.
      Apparently the lap button does not work to skip a step in a structured workout or a guide. I recently bought a Race S but apparently it happens with other watches (?).
      Help!
        far-blue Bronze Member
        I wasn’t aware that was a functionality that was supposed to exist / work 🙂 If a structured workout has a step that finishes on manual lap button then I know that works for me as I have workouts that use it but that’s specifically set in the workout.
        Genis MajoralG 1 Reply Last reply Reply Quote 1
          Genis Majoral @far-blue
          @far-blue Even with a workout where th warm-up duration is set to “until lap press” it does not work. The workout is stuck forever at the warm-up.
          DesdinovaD 1 Reply Last reply Reply Quote 0
          • DesdinovaD Offline
            Desdinova Bronze Member @Genis Majoral
            @Genis-Majoral test it on the other screens during the activity perhaps?
            Genis MajoralG 1 Reply Last reply Reply Quote 0
              Genis Majoral @Desdinova
              @Desdinova apparently the skip lap button only works in the “basic” running mode. So for some reason when you create a custom sports mode it loses this ability to skip a step. I have tried all combinations (press length, press on different screens, turn off all other S+, deactivate autolaps…) but nothing changes.
              A new lap is created but it does not skip the S+guideline lap… (in a custom sports mode). As I said it does work in the “basic” (default) sport modes.
              Still I would suggest to add this functionality to custom sport modes.
                false Bronze Member @Genis Majoral
                @Genis-Majoral it’s an old bug with workaround - when starting an exercise and a watch asks about structured workout choose “no”, then choose your planned workout from suunto apps menu
                PS I don’t why it’s not fixed yet
                  isazi Moderator @false
                  @false I will try to ask tomorrow, or better, check if it works on the next firmware
                    Tested on a 9 Peak Pro with latest FT firmware, ending a step with the lap button press works also in custom sport modes.
                    Just wait a couple of weeks for the new firmware to be released.
                    F Genis MajoralG 2 Replies Last reply Reply Quote 1
                      false Bronze Member @isazi
                      @isazi so probably the topic starter doesn’t have the latest FW installed (neither do I, so I use that workaround)
                      but it’s very old bug, I remember it from last year, that’s why I left a postscript
                        @false you cannot have that, it is not released yet. I am just telling you that has been fixed and will be available to production in next release.
                          @isazi ok, cool! let’s see
                            Genis Majoral @isazi
                            @isazi Thanks a lot!!!
                              I’m not sure if this is related but today I had a workout where the last step was an open one to ‘run back’ and I completed it with the lap button. I believe it did complete the workout and I soon after stopped the activity as usual however I then found the laps that should have been created as part of the structured workout had disappeared and the entire structured workout duration was lumped into a single lap and where I’d pressed the lap button to complete the workout step had been recorded as the transition from lap 1 to lap 2 rather than appending the workout laps.
                              I hope that makes sense!
                              Basically I expected laps for warmup, tempo interval, recovery, another tempo interval, and a cooldown (with the manual end on lap button).
                              What I actually got was 47 mins (the entire structured workout) for lap 1 and 20s for lap 2 where I walked, paused then stopped the activity.
