    HRV. and VO 2 Max
    13 Posts 6 Posters 797 Views 6 Watching
    • R Offline
      Retired Assistant
      I have had the excellent Vertical Solar titanium for several months now. Still, sadly, despite following all the instructions from support and the generous people on this forum, I have never been able to get either HRV or VO2 Max measurements. They seemed to cease on or about January 8 of this year.
      I was wondering if anyone else has had this problem.
      ? JonasLarssonJ Mff73M 3 Replies Last reply Reply Quote 0
        A Former User @Retired Assistant
        @Retired-Assistant for me to get HRV I pushed my resting heart rate up 6 BPM and it started to register.
        I can’t speak to VO2 Max as I’m not a runner and it appears that’s the only way it registers. I know that is also tied to HR and maybe you could adjust the threshold to get it to pick up? (Just thinking out loud)
        R 1 Reply Last reply Reply Quote 1
        • R Offline
          Retired Assistant @Guest
          @Todd-Danielczyk
          Thank you for replying. I will follow your advice and see what develops.
          Logging all my hikes, walks, and workouts and then finding that the software renderers no metrics is frustrating.
          • JonasLarssonJ Offline
            JonasLarsson @Retired Assistant
            @Retired-Assistant That doesn’t sound good. VO2 Max is sometimes hard to get but the HRV should be there. I don’t have any help to give more than maybe reaching out to Suunto could be a good idea.
              Mff73 @Retired Assistant
              @Retired-Assistant
              you mean HRV during sleep tracking, right ?
              Where else is there HRV measurement that seems to have ceased for you in Janurary ?
              • R Offline
                Retired Assistant @Mff73
                @Mff73
                In fact I have never had any HRV measurements since I had the watch despite employing all the firmware updates and updating the app on a regular basis.
                Everything else works fine.
                The only problem seems to be with these two components.
                  isazi Moderator @Retired Assistant
                  @Retired-Assistant what is your normal HR at night? Did you enable 24 hours HR and sleep tracking? Have you enabled HRV tracking during sleep?
                  • R Offline
                    Retired Assistant @isazi
                    Thank you for getting back to me.
                    My normal resting heart rate at night is between 58 and 62bpm.
                    All the other elements you mentioned are enabled.
                      @Retired-Assistant I thought it may be that you have an extremely low HR at night, but no, so I am not sure why it does not work for you 😕
                      GiPFELKiNDG R 2 Replies Last reply Reply Quote 0
                        GiPFELKiND Silver Members @isazi
                        @isazi said in HRV. and VO 2 Max:
                        Hey @isazi do you know if suunto planned a HRV measurement in daytime? Like a 2minutes test wich we can start at any time? 😁To track the stress at the Moment?
                          isazi Moderator @GiPFELKiND
                          @GiPFELKiND I do not think so
                          • R Offline
                            I have loaded the new firmware and see where that takes me.
                            Strange, but I have never had this problem with Apple or Garmin.
                            Because I like the watch so much, I am going to continue to try to make it work.
                            Thank you once again.
                              @Retired-Assistant I believe you should contact support, VO2max may be because of your use, but HRV should work
