    Suunto ZoneSense
    966 Posts 149 Posters 219.0k Views 126 Watching
      Egika Platinum Member @nseslija
      @nseslija said in Suunto ZoneSense:
      @TrailEyes Link is not working…
      works for me
        isazi Moderator @The_77
        @The_77 let me comment on this. The mapping between ZoneSense and thresholds in terms of HR is there mostly because people like their zones, and would fight over the number and meaning of them, even if science says that you basically have three cardio zones 🙂
        So, ZoneSense is a way to get rid of zones, and have another metric to separate aerobic/anaerobic/VO2max efforts during a workout.
        But, people want zones, so using ZoneSense it would also be possible to get aerobic/anaerobic zones to set your thresholds accordingly, especially if you do not use a chest strap at all times. But ZoneSense uses data that can change day by day, during the same day, affected by temperature, stress, food and drinks, and everything else.
        So, no need to change your zones every single day because of what ZoneSense may say, better to still plan tests for aerobic and anaerobic thresholds, and see what ZoneSense tells you about these workouts, and set your zones.
        And if one day you see that your HR is Z2 according to the zones you set, but ZoneSense on the S+ app tells you that you are in anaerobic or VO2max effort, maybe that day you are particularly tired and can lower your effort 🙂
        T Dušan KovićD AntoineA M 4 Replies Last reply Reply Quote 16
          The_77 Silver Members @isazi
          @isazi that’s what I thought - the underlying data of aerobic or anaerobic lined up with what I already thought, just the number seemed a bit off.
          And re: days you are tired, I found one of those where my HR data was clearly suppressed and Zone sense could show I was working much harder than it would otherwise appear (and I could tell from doing the run that I was lackluster on the day) 👍
          On a separate note: how is ZoneSense managing with quality of data, i.e. dodgy strap connection due to battery/moistness. Data filtered out from calculations?
          • N Offline
            nseslija Bronze Member @Egika
            @Egika Working now 🙂
            Ambit 2S
            Ambit 3 Peak
            Suunto 9 baro
            Suunto Vertical Ti Solar
              @The_77 yes, data is filtered out, and there are even more checks in the app after the activity, so values during and after may be a bit different, but should not differ too much… or your strap may not be working properly
              • Dušan KovićD Offline
                Dušan Ković @isazi
                @isazi The more I read about this, the more amazing it looks. Great way to get rid of 5 zone system, anaerobic and lab tests, and just train in personalized manner
                SR
                SA latest beta
                Polar Verity Sense
                Polar H10
                Pixel 6
                • AntoineA Offline
                  Antoine Bronze Member @isazi
                  @isazi said in Suunto ZoneSense:
                  Ok, so now, there is no need to define accurate HR zone. ZoneSense does not use HR zones defined in the watch that’s right ?
                  Suunto vertical solar
                  Coros arm HRM / Suunto wing 2
                  Android A55 Samsung
                  T EgikaE 2 Replies Last reply Reply Quote 1
                    The_77 Silver Members @Antoine
                    @Antoine I suppose for training load purposes it’s useful within the Suunto remit to semi-regularly check your anaerobic limit for TSS purposes, but evidently you can get this from ZoneSense.
                      Egika Platinum Member @Antoine
                      @Antoine correct. HR zones are not a factor in the ZoneSense algorithm. You can adjust your HR zones based on the outcome of ZoneSense to use in activities without a HR belt.
                      Or in watches that don’t have the live data information.
                      • AntoineA Offline
                        Antoine Bronze Member @Egika
                        @Egika said in Suunto ZoneSense:
                        @Antoine Ambit 3 belt will do. It has RR measurement and is BT.
                        There is no RR (RR memory, it is quite new)
                        This is this one:
                        https://www.suunto.com/fr-fr/Produits/Ceintures-de-frequence-cardiaque/Suunto-Smart-Sensor/
                        Android A55 Samsung
                          @Antoine said in Suunto ZoneSense:
                          This is this one:
                          Memory is not needed. Ambit’s HR belt definitely has RR data, as it was the first watch do calculate respiration rate from this data.
                          • tazidenT Offline
                            taziden Gold Members
                            Feature request: get rid of the 5 circular segments around the screen, replace them with ZoneSense zones please 🙂
                            S9PP
                            isaziI flucaF 2 Replies Last reply Reply Quote 17
                            • Matija SM Offline
                              Matija S Bronze Member
                              This looks great! Didn’t try it on a watch yet, but post analysis for past workouts shows data. Used Polar chest strap.
                                Brad_Olwin Moderator
                                I can comment on this as well. During testing I “ran” 3 4300 m peaks one day after another for 3 consecutive days. By the third day I was fatigued and the Zone Sense aerobic HR had dropped significantly in the post analysis. This will be extremely helpful in real time when racing as it will allow you to change effort to avoid the ultra death march.
                                First image Mt Elbert was first peak and 2nd image was 3rd peak on 3rd day
                                stromdiddilyS 1 Reply Last reply Reply Quote 8
                                  For what period of time does SuuntoSense calculate data? As far as I understand, if you enter SuuntoSense in SA activity, there will be zones calculated using HRV (not zones from the watch)? I compared these zones with the zones set in TP (and in the watch, respectively), and these zones are 100% similar. d2eeb83a-50fb-4251-b95d-81c251f929ef.jpeg b2792e56-47e0-4ca7-bd9e-6e0f4252f10e.jpeg
                                    Egika Platinum Member @Sergei Ladeishchikov
                                    @Sergei-Ladeishchikov your screenshot from SA shows only the zones set in the watch.
                                    If ZoneSense comes to the conclusion that they are different, it will show this in a separate column.
                                    Sergei LadeishchikovS 1 Reply Last reply Reply Quote 0
                                      Sergei Ladeishchikov Bronze Member @Egika
                                      @Egika Thanks for the info! So SuuntoSense thinks my zones are relevant to the calculations? Does anyone have a screenshot of what it should look like?
                                        There is no “should”.
                                        Just if ZoneSense has data that leads to adjusting the threshold it will look this this:
                                        Matija SM 1 Reply Last reply Reply Quote 3
                                          Matúš Bronze Member @isazi
                                          Maybe I do not get the exact point of ZoneSense, but if I go out running some reps, there is at least one activity screen that shows both time/distance field and HR data, i.e., the “old” HR zones.
                                          I’ve just tried the ZoneSense app and, as expected, the “new” zones are shown as aerobic/anaerobic/VO2max but, even by changing the data fields through the upper button, neither time nor distance data are shown: so, how to workout some reps without the need of changing activity screen to check distance/time and zones?
                                          Suunto Spartan Sport
                                          #swatt
                                          • stromdiddilyS Offline
                                            @Brad_Olwin said in Suunto ZoneSense:
                                            I have one more peak long weekend before my 100 on the 5th. May just have to give this exact scenario a go 🙂
