    Custom battery mode + and pause button when seeing maps
    6 Posts 4 Posters 635 Views 4 Watching
    • V Offline
      Vemee
      I have two questions.
      1. I can see in many threads in the forum about creating a custom battery mode. How is this done? I can not find it in the manual or when going through the watch.
      2. During an activity when the map-screen is active (navigation) I am not able to pause the activity with the top button as on other screens during a workout. Why is this? The top button is not used for anything else. The time one uses the navigation/map is when in unknown locations. If you are in an unknown city there might be some traffic lights which you need to stop by, and you simultaneously want the map page on, it is a bit annoying.
      Any help is much appreciated ๐Ÿ™‚
        Egika Platinum Member @Vemee
        @Vemee
        1. custom battery modes only exist in MIP display watches S9PP and Suunto Vertical. Race does not have it
        2. The users here do not not know the reasoning behind certain design decisions. We can only speculate. It wonโ€™t help anyway. You are not the first with this idea and it has been forwarded to Suunto devs already.
        Cheers!
        V 1 Reply Last reply Reply Quote 2
        • V Offline
          Vemee @Egika
          @Egika Tanks for reply, then I can stop searching ๐Ÿ™‚
          • dankcushionsD dankcushions referenced this topic on
          • George KatsanosG Offline
            George Katsanos
            so everytime I start my walk/run, I NEED to manually switch to Endurance!? this is ABSURD!!!
              elbee @George Katsanos
              @George-Katsanos said in Custom battery mode + and pause button when seeing maps:
              Iโ€™m not really know what you mean exactly. On my race s, I can specify the battery setting per activity and it remembers that setting. So for running you can specify best accuracy and for hiking longest battery life. Just have to specify it once per activity.
                Egika Platinum Member @elbee
                @elbee hm, at least in my Vertical 2, the battery mode is not remembered. I set it to Endurance for an activity, but the next time I start this same sport mode, it starts over with Performance.
                @george-katsanos: Are your walks and runs so long, that the 50/60h of recording time in performance mode are not enough?
                With your input, this post could be even better ๐Ÿ’—
