    Battery life on Suunto 9 Peak Pro during ultras?
    battery lifesuunto 9 peak pro
    15 Posts 7 Posters 2.5k Views 7 Watching
      Tarrintaal
      Has anyone tested the battery life on the Suunto 9 Peak Pro during a ultra trail marathon lasting 30-40 hours with navigation on? How can I best optimise my watch setup to make it last?
        MKPotts Bronze Member @Tarrintaal
        @Tarrintaal
        Yes, on many ultras ranging from about 4.5hrs/50km to 100hrs/450km. I normally have the watch permanently on the navigation screen and as far as I can tell it makes no real difference to how long the battery lasts.
        You will definitely be ok for 30hrs unless you have the backlight on. If closer to 40hrs, you might need to be careful about some settings (though, if you’re out for that long, you’ll almost certainly have at least 10-15mins in an aid station at some point, where you could easily add about 25% points to the battery with a power bank).
        Specific things to consider:
        Backlight - turn it off completely, including raise to wake. If it’s too dim to see the watch without it, you will/should have your headtorch on anyway.
        Autolaps - vibration & backlight when they trigger can add to battery drain, turn off or set infrequently (e.g. every 10km rather than every km).
        Wrist HR - can you use an external sensor or just not bother with HR at all? When using an external sensor I get battery drain consistent with a 50-55hr run time (performance mode, autolaps every km, always on the map screen, climb alerts on). The wrist HR isn’t accurate for me so I’ve never used it on an ultra - therefore not sure if 40hrs+ is reliably achievable with it on. Hopefully others on the forum will have some experience to share - but if using the wrist sensor and likely to be out for nearly 40hrs, I’d make sure you are able to charge the watch briefly (10-15mins as above) if needed.
        SuuntoPlus apps - I don’t know but some might increase battery drain, so don’t use any unless you really need them. Because I’m on the map screen all the time I don’t use any. I’d guess that those processing data that otherwise wouldn’t be (e.g. ZoneSense) could use more extra power than those just repackaging core data (i.e. time, speed and distance based stuff) but I don’t know.
        In two of my recent ultras, using the configuration described - performance mode; backlight off; always on the map screen; 1km autolaps; climb alerts on; screen always on (no timeout); no SuuntoPlus; connected to either a Polar Verity Sense or Suunto HR belt - battery drain has been:
        25hr48min, 170km - 47% battery used
        9hrs6min, 85km - 17% battery used
        For a 51hr/300km race last year, set as above except no HR sensor (wrist or external), it lasted the race with I think about 10% battery left.
        Hope this helps. I’ve found the watch great for ultras - I think I’ve used it for 9 so far, covering about 1900km - so let me know if any other questions about how I’ve used it.
        What race are you doing?
        T 1 Reply Last reply Reply Quote 6
          Tarrintaal @MKPotts
          @MKPotts
          Thank you for the advice.
          I ran UTCT miler. 34hours on full navigation and with HR strap. Dimmed backlight to low and switched off all autolaps and notifications/tones/vibrations. Climb alerts were on. No SuuntoPlus guides.
          Still had 18% battery life left when I finished.
          • Peter Pan 0P Offline
            Peter Pan 0
            Hello. This is not exactly concerning battery life but sync and GPS during ultra.
            I just did a 100mile. 29h. battery still on 18%, HR strap, light, vibration, notification on, so absolutely no problem there.
            Then I synced to App.
            Activity shows 161km, which is according to my readings. However, the map doesn’t show the last 1.5 km (approximately) although start and finish where at the exact same location.
            Also in the app it takes a very long time to load the data, i.e. map, statistics, HR data etc. Anyone has same experience?
            S Mff73M 2 Replies Last reply Reply Quote 1
              skifast12 @Peter Pan 0
              @Peter-Pan-0
              I ran a 210k ultra in 2022 with it and it dumped the last 7km off the map. Interestingly all the data was stored but something glitched so it looks like I ended the race at the top of a mountain. I attribute this to several interrupted upload attempts post-race where the cellular service was very very weak, but who knows.
                Mff73 @Peter Pan 0
                @Peter-Pan-0
                Suunto 9 or 9peak pro?
                You are double posting?
                https://forum.suunto.com/post/195536
                SSU (retired), SV1, SV2
                Android + Galaxy S205G
                Peter Pan 0P 1 Reply Last reply Reply Quote 1
                  Peter Pan 0 @Mff73
                  @Mff73 S9pp
                  Yeah sorry I am not really sure if it’s watch or app related problem??
                  Funny enough I loaded the JSON file here,
                  https://smlanal.szmigiel.design/
                  And it shows 159.85km?? Not the 161km.
                  It appears GPS tracking just stopped at 159km??
                  But then how does it end up being 161km shown on the watch?
                  EfejotaE Mff73M 2 Replies Last reply Reply Quote 0
                  • EfejotaE Offline
                    Efejota Bronze Member @Peter Pan 0
                    @Peter-Pan-0 I guess that the watch uses the accelerometer to calculate the approximate distance without GPS. If I am not mistaken, it is the way it can calculate distance/speed when running without GPS coverage (i.e., under a bridge). My guess is that the watch at some point stops using GPS to save battery in critical conditions (as with other functions) but keeps recording until battery is completely depleted and uses the accelerometer as an alternative.
                    D 1 Reply Last reply Reply Quote 2
                      Mff73 @Peter Pan 0
                      @Peter-Pan-0
                      I think as @efejota.
                      You might have missed (if there was one) the watch warning that it will change to some ultra mode…
                        duffman19 @Efejota
                        I don’t think this is it. He said he still had 18% left at the end of the activity. On older firmware, things used to shut down more aggressively, but that was some time ago. The first low battery warning does pop-up at 20%, but does not affect any settings. IIRC, things don’t start to shut down now until around the 5% range.
                        Although, I suppose things could be different for such a large activity. Perhaps the 9PP was running out of memory at that stage? The fact that the activity distance is longer than the GPX distance does suggest that it shifted into Tour mode (GPS logged every 30 minutes) for the final 1.5km, logging one final GPS point at the end of the activity, but not connecting it to the GPX trace.
                        I seem to recall some other folks having issue uploading extra long activities to SA, but can’t recall if it was watch model specific.
                          Peter Pan 0
                          Thanks all.
                          I was wondering if it was due to activity sync possibly interrupted. Then I was wondering if I re-upload maybe it’s fixed?
                          But then… If I delete on SA how do I force re-sync for that activity? Or is it all transferred to SA and apart from basic info not on the watch any longer after initial sync? Therefore a resync would not work anyway?
                            duffman19 @Peter Pan 0
                            @Peter-Pan-0 It should all still be on the watch. You can check by going to the Logbook. If it has all the stats just like the activity summary screen, especially the graphs (HR, zone chart, elevation profile), then all the data should still be on the watch. If it only shows a small summary of distance and time, then the full dataset is not on the watch. Activities are deleted from oldest to newest to free up room when necessary.
                            I’ve had to recover activities stored on the watch before and it isn’t totally straight forward. I think the process goes something like this:
                            • Delete the activity from SA
                            • Unpair watch from SA and remove SA connection from watch (Settings > Connectivity > Paired devices > MobileApp)
                            • Remove watch from phone’s BT connection
                            • Sign out of SA (this removes an activity data saved to the device)
                            • Close SA (you can go one step further and delete/redownload SA, but I don’t know if that’s necessary)
                            • Open and sign back in to SA
                            • Re-pair watch
                            When the watch is re-paired, SA will look for any stored activities on the watch that are not already attached to your account.
                            Honestly, all you might need to do is delete the activity and then sign out and back in to SA. The above just covers all the bases.
                            I’ll stress that this has worked for me in the past, but, obviously, make sure you save a backup of the activity before you delete it! Either directly from the Suunto App or from another connected service. If, for some reason, the above doesn’t work, there are ways to get the .FIT file back on to your Suunto account, although that’s not straight forward either.
                            Peter Pan 0P 1 Reply Last reply Reply Quote 0
                              Peter Pan 0 @duffman19
                              @duffman19 thanks I will try.
                              I can export a fit or JSON file. But how would I insert it later in case it doesn’t sync the deleted activity?
                                @Peter-Pan-0 The only way I know is to use a third party app, like RunGap, to sync it back to the app. I don’t think there is any way to upload it directly to SA.
                                  @duffman19
                                  So I tried first with a short stretching activity. Delete from SA, log out of SA, login again, resync and it showed the activity again.
                                  However. doing so with my long run, seems to not resync although it’s still on the watch (at least showing on the watch.
                                  I noticed. Daily HR, steps, resources are all in SA including the activity time. But GPS and activity stats are not. Would be great to ad Fit/json manualy Back into SA. That’s possible?
                                  Is it possible json and fit files are deleted if you uninstal SA?? Would be an explanation I can’t find them on my phone anymore.
