    Battery charge error.
    3 Posts 1 Posters 778 Views 1 Watching
      Leonid Yasyukevich
      The watch started to switch to the mode (image: battery needs to be charged) without notification. The last error showed the charge value of about 90%, before that it happened a couple more times similarly with the charge value of about 45%, but it happened right during a run, which surprised me greatly, because I remembered that the battery charge was still sufficient. I completely discharged and charged the watch and performed a full reset to factory settings. Today I tried to reinstall the latest update and once again performed a full reset to factory settings. But why this happens remains an unpleasant mystery to me. Thanks in advance for any help!
      9 Peak Titanium (43 g.)
      Ambit 3 Sport
        Leonid Yasyukevich @Leonid Yasyukevich
        So, the actions point by point in case of this error:
        1. The battery needs to be completely discharged.
          When the battery is between 2 and 5%, the watch displays the symbol that the charger needs to be connected. Normally, we didn’t need to discharge the clock to 0%. Press the buttons and make sure that the watch is discharged or continue to discharge to 0%.
        2. Connect watch to the charger and wait until 100%.
          When connected, the battery management will be triggered and the special battery charging symbol will appear.
          This is where the mistake lies. And this is exactly the solution. Simple, but not obvious.
        Also, this procedure solves the problem of energy leakage after the updates.
        I suggest closing the topic or pinning it. Happy New Year to all.
        Ambit 3 Sport
          And i forgot to mention🤔
          3.Perform a full reset to factory settings.
          Settings->General->Reset settings
          Ambit 3 Sport
