    Suunto vertical titanum solar - NEVER AGAIN SUUNTO !!!
    23 Posts 16 Posters 2.7k Views 17 Watching
    • jjorgemouraJ Offline
      jjorgemoura
      On a similar note, I have the same but for pace on treadmill. It has started 1 week ago. No software update in the meantime.
      So, probably an hardware issue. Maybe. However, this SV is “new”, was replaced by support in last November due to an issue with my original SV.
      Note, a soft reset doesn’t solve the problem.
      Note: a 30min/Km pace is like a baby crawling.
      Between hardware issues (like I said, this SV is new, it was replaced under warranty) and software issues, the trust and confidence in the device/brand is getting eroded quite quickly.
      Suunto 9 Baro Titanium
      • Frederick RochetteF Offline
        Frederick Rochette Bronze Member
        I have the same issue with my SV since the last update and I whant to return to the previous FW. How can I do that?
        jjorgemouraJ 1 Reply Last reply Reply Quote 0
          jjorgemoura @Frederick Rochette
          @Frederick-Rochette You can find instructions here in the Forum on how to install previous FW.
          However, I contacted support and in order to fix the problem I did:
          • Installed previous FW (the one before December). Didn’t solve the issue.
          • Factory reset. First treadmill session after was normal but problem come back on from second run on.
          • Installed the latest FW version, the one released this February (the fix of the bad one from December). Initially didn’t change anything. However, several treadmill sessions later, the watch is now working correctly again (detecting the correct pace in a treadmill session).
          So, no idea of what’s going on here.
