    Connecting earbuds
    3 Posts 2 Posters 370 Views 2 Watching
    • Maja MpikaM Offline
      Maja Mpika
      Hi.
      I’m new to suunto from Garmin for the past few years.
      The vertical solar is on my wrist for less then 24h.
      I was not able to find how to get notifications about the run this morning.
      While on Garmin I didn’t need to do anything, earbuds connected, music going, music silenced down every 10’ to get info about speed, power etc?
      Earbuds connected to phone, music on, but no notifications about the run?
      Read the how to, watched YouTube but can’t figure it out?
      TIA
        far-blue @Maja Mpika
        @Maja-Mpika The notifications will come from your phone and to enable the notifications there is a per-activity-type setting on your watch. Before you start the activity if you scroll down to ‘Exercise Options’ and then turn on ‘Voice Feedback’ it should work for you. You can also choose whether you want auto lap info, HR zone change or both. Luckily, this setting is also remembered for future uses of that activity profile 🙂
        I don’t think the audio feedback feature is as strong as it is with Garmin but I hope it’s an area Suunto will focus some development on soon 🙂
        Maja MpikaM 1 Reply Last reply Reply Quote 0
          Maja Mpika @far-blue
          @far-blue hi
          It just did, on it’s own.
          Now I have a different issue.
          HRM pro plus and running dynamics not working together at the same time on a treadmill or anymore.
          Both Garmin.
          Tried everything.
          Even pulling out batteries from both, forgot both, reconnected both and then I reconnected just the HRM. Works!
          Disconnecting HRM and connecting just the pod doesn’t work, adding GPS(talking treadmill) doesn’t help.
          I did the run outside two days ago. All behaving perfectly, just like Garmin
          Did the treadmill this morning and kept disconnecting, like half the data dropped out, including steps, making the stride length 200cm when I corrected the length of the run.
          Looks like Google was right when it said that the Garmin running dynamics doesn’t work on other watches (it did perfectly so just once.)
          Problem is(or not) that on my narrow treadmill I have to keep a hand on the bars otherwise I could fall(and the treadmill was actually because of an ankle injury)
          I changed the steps on the suunto app and that doesn’t show either on the main page nor the watch itself.
          Thanks muchly for the answer
