    Running navigation takes ages to turn on
    4 Posts 3 Posters 341 Views 3 Watching
    • VanillafaceV Offline
      Vanillaface
      Not sure when it is started since I’ve been using the watch for only 1 month.
      But the problem is that when I choose an activity to run, the navigation icon is not turning green for a few minutes.
      Is it only for me or maybe I have to do something?
      My navigation setting for running is breadcrumbs.
      Mff73M Brad_OlwinB 2 Replies Last reply Reply Quote 0
        Mff73 @Vanillaface
        @Vanillaface
        Do you switch your watch off sometimes? Or is it mostly on, and your are wearing it regularly, and suunto app is connected to it?
        Another question to help trouble shoot, when this happen, are you in a location “far” from the last time you ran?
        VanillafaceV 1 Reply Last reply Reply Quote 0
          Vanillaface @Mff73
          @Mff73
          Hi!
          I never turned off my watch yet.
          I always use suunto app and syncing it with watch (1-2 times a day).
          I ran always in same area. I live in center of capital city.
            Brad_Olwin Moderator @Vanillaface
            @Vanillaface Check Settings/General/About on the watch and scroll down until you see Assisted GPS. This should have the current date. If not the file for finding satellites is not loaded.
            A second issue is that this file requires a few minutes to unpack. If it syncs to the watch immediately before an exercise it will take much longer to get a GPS lock. Your lock (solid green arrow) should take only a few seconds if you have a good view of the sky.
