    Battery consumption when not using activities
    7 Posts 3 Posters 527 Views 4 Watching
      • fw v. 3.18.44
      • 2 manual syncs per day (otherwise bt is always off, so no notifications etc)
      • britghness set to low
      • aod off
      • off screen time set to 10s
      • raise to wake enabled
      • HR 24/7 enabled
      • Sleep + HRV tracking enabled
      • DND on when sleeping
      when not using activities battery drops ~16/17% a day and to me it seems a tad high.
      Thanks!
        isazi Moderator @Guest
        @6iovanni seems also high to me, I do not particularly like the battery consumption during activity, but in daily mode is quite good in my experience. Maybe something that is fixed in next update (I am running a newer firmware). Did you try rebooting the watch already?
        Also, sometimes watches seem to consume more for the first one/two cycles and then settle.
        ? 3 Replies Last reply Reply Quote 1
          A Former User @isazi
          @isazi said in Battery consumption when not using activities:
          Can’t say anything about that because I’ve had all enabled (music, chest strap, earpods, activity, following a track) but I guess 10%/h or so
          I’ve made a sw reset right now
          Probably!
          Thanks!
            One question if I may. Since you have the opportunity to wear several watches, I’d like to know (I hope this does not violate NDA) how comparable the HRV is between this watch and e.g. the Vertical. I ask this because of the different 24/7 HR management of the Run.
            isaziI EgikaE 2 Replies Last reply Reply Quote 0
              @6iovanni comparable, for me all watches and the Oura ring give basically the same numbers at night
                Egika Platinum Member @Guest
                @6iovanni said in Battery consumption when not using activities:
                HRV is totally comparable.
                Run for me just has a much higher HR accuracy than Vertical during activities.
                  @isazi just to report that the latest update or the few charging cycles or both have improved the battery
