    Firmware 3.19.16
    38 Posts 13 Posters 1.6k Views 14 Watching
      Gunnar Bronze Member @ShinJCD
      @ShinJCD Did you have better tracks on this route before? With Suunto Run or other GPS watch?
      ShinJCDS 1 Reply Last reply Reply Quote 0
      • ShinJCDS Offline
        ShinJCD
        I’m returning to the topic of “GPS quality.” This afternoon’s run: in the first red circle on the left, you can see a noticeable deviation from the main road. I enter my town’s sports field: there’s no running track (there used to be, now it’s just dirt and grass, but I can more or less run a 400-meter lap regularly), so I start running several laps, using predefined points as reference points (to ensure the laps are as “regular” as possible). As you can see from the rightmost circle (I highlighted this one because the deviation is more glaring), there are some errors in the GPS that, in my opinion, are too serious to be real… I should point out that, in this case too, I waited for a GPS signal before starting the run, with the battery set to “performance,” and that the sports field is completely outdoors.
        • ShinJCDS Offline
          ShinJCD @Gunnar
          @Gunnar said in Firmware 3.19.16:
          Before the Suunto Run, I used a Huawei Fit 3, and the GPS tracking was nearly perfect. I’ve previously owned several Amazfits and a couple of “WearOS” smartwatches (Ticwatch and Oppo), but I’ve never encountered any issues like this. The Suunto Run is my first “serious” sports watch, and obviously, I wasn’t expecting such poor quality in this regard.
            @ShinJCD I am no expert but your tracks look really bad. Perhaps a faulty device?
              Egika Platinum Member @ShinJCD
              @ShinJCD you can use the track mode. It will also allow for running to and from the track nicely.
              Run Lime
              • giovanni.G Online
                giovanni.
                Today for the first time ever during the usual midday jogging the watch froze and restarted twice in a row. Both times it did not save anything 🤔
                Another thing to report: as soon as I take the sensor off the chest strap, the sensor disconnection notification comes several minutes later (when I wear it, it is almost instantaneous)
                Suunto Run
                • ShinJCDS Offline
                  ShinJCD @Egika
                  @Egika said in Firmware 3.19.16:
                  I know, but I wanted to do this simple test just to evaluate the quality of the GPS
                  • ShinJCDS Offline
                    ShinJCD @Gunnar
                    I don’t know, in other circumstances like this (a simple walk on the beach) I haven’t noticed any problems.
                    • Yves JenniY Offline
                      Yves Jenni @isazi
                      @isazi said in Firmware 3.19.16:
                      Automatic workout save on low battery
                      Unfortunately, the activity isn’t saved if the watch shuts down due to an unknown problem. The shutdown doesn’t seem to be the trigger for the emergency save.
                      Problem description:
                      Today, the Suunto Run (software 3.19.16) had a few problems. During the first run, the connection to the Suunto Smart Belt was lost twice. I was able to reconnect manually. Later, it took three attempts to connect headphones that were already known. The second run went smoothly with the belt and headphones. During the third run, the watch suddenly vibrated and I saw the Suunto logo. The run wasn’t saved.
                      giovanni.G 1 Reply Last reply Reply Quote 0
                      • giovanni.G Online
                        giovanni. @Yves Jenni
                        Hi @Yves-Jenni
                        it’s funny because today at noon the same thing happened to me! hope our report reaches the devs.
                        Suunto Run
