    Suunto Smart Heart Beat belt connected, used, or not?
    11 Posts 4 Posters 1.9k Views 4 Watching
    • Patrick HollingP Offline
      Patrick Holling
      Hallo,
      ich nutze eine Race S mit den Suunto HR Belt dazu. Die App sagt der Gurt ist verbunden, meine Uhr zeigt mir dies allerdings nicht mit einem besonderen Symbol! Ist es richtig, dass meine Uhr ein grünes Herz mit einer Art Gurt zeigen sollte, anstatt des Herzen für den optischen Sensor? Wüsste natürlich gern, ob mein Gurt wirklich funktioniert.
      Same Question in english 😉
      I’m using a Race S with the Suunto HR belt. The app says the belt is connected, but my watch doesn’t show this with a specific symbol! Is it correct that my watch should show a green heart with a kind of strap icon instead of just the heart symbol for the optical sensor? Of course, I’d like to know whether my belt is actually working.
      • G Online
        Gunnar Bronze Member @Patrick Holling
        @Patrick-Holling yes, the watch should show a different heart icon than for the inbuild OHR.
        Patrick HollingP 1 Reply Last reply Reply Quote 0
          Patrick Holling @Gunnar
          @Gunnar
          Ok, thanks for the fast reply. Then I have to figure out why it is not working. Then I made my last runs, with the belt only for holding my breast high 🤣 Hope it will work, tried everything, except a new battery… that’s my last option…
          • G Online
            @Patrick-Holling try to connect it to your mobile. Is the belt using bluetooth or Ant+? Ant+ does not work with your watch.
              @Gunnar
              unfortunately it is not working, wherever I put it on my chest. Using all methods of moisturizing my chest. Sometimes, 1 in 20 attempts it shows a heartrate for a few seconds. Those are 80€ for my a***** !
              EgikaE Mff73M 2 Replies Last reply Reply Quote 0
                Egika Platinum Member @Patrick Holling
                @Patrick-Holling if your app is telling you, the belt is connected, then it is connected to the app.
                The belt can have only one connection.
                Disconnect the app from the belt and start pairing the belt from the watch (settings -> connectivity -> pair new device)
                Only after this, the watch will be able to use the belt during activity.
                Patrick HollingP 1 Reply Last reply Reply Quote 2
                  Mff73 @Patrick Holling
                  @Patrick-Holling
                  I would have explained exactely like @Egika.
                  SSU (retired), SV1, SV2
                  Android + Galaxy S205G
                    Patrick Holling @Egika
                    @Egika
                    awesome, this works for me ! Now I see the sign with the strap, when I start an activity!
                    Nevertheless, now I have put my belt aside, because I don’t want to use it anymore for today. The heart on my watch, is still „strapped“ , when I start a run ! Doesn’t it change back to the optical sensor by itself, or do I have to move further away from my belt, or something like this ?
                      @Patrick-Holling yes. once the watch is connected to the belt, it will try to use it. The belt itself switches itself off after like 15mins or so.
                      What you can do: Go into the the training option before starting and disable the belt.
                        @Egika
                        awesome, yes I figured it out, how you advised. 😉 you should work for SUUNTO, if not already doing. All the best from Germany
                          @Patrick-Holling
                          Cheers from Hamburg 🙂
