    240 Posts 59 Posters 8.9k Views 54 Watching
      maszop Bronze Member @Jan Suchánek
      In my opinion, routable maps on watches are overhyped. The screen is too small to check or improve automatically generated routes. While this might not be a problem in the city, it’s worth checking routes on a larger and more responsive phone screen when outdoors.
      Of course, they’re nice to have, but a much more serious problem with Suunto is the SuuntoApp lack of a true offline mode. You can’t download and edit routes, create a route, or share it with others, and you can’t use previous activities saved in the Logbook without first syncing them — which requires an internet connection.
      This is a real problem.
      JosaipluJ 1 Reply Last reply Reply Quote 5
      • JosaipluJ Offline
        Josaiplu @maszop
        @maszop Did you check the youtube link I have posted ? it seems that this offline mode will came before end of year according to Joaquim. I never used the routable maps on my enduro 3 TBH so i will not miss the feature that much and I always run/hike/bike with my phone
          maszop Bronze Member @Josaiplu
          @Josaiplu After assurances about contour lines and map updates “by the end of the year”—I don’t remember which year that was 😁 — I’m taking such assurances with a grain of salt. They’re currently nonexistent, and that’s a serious problem for watches designed for outdoor use.
          JosaipluJ sky-runnerS 2 Replies Last reply Reply Quote 2
          • JosaipluJ Offline
            Josaiplu @maszop
            @maszop Understood ;D hope this “end of year” will be realistic so 😉
              sky-runner Silver Members @maszop
              @maszop said in Suunto Vertical 2 General Discussion:
              BRONZE MEMBER
              @Josaiplu
              about a minute ago
              @Josaiplu After assurances about contour lines and map updates “by the end of the year”—I don’t remember which year that was — I’m taking such assurances with a grain of salt. They’re currently nonexistent, and that’s a serious problem for watches designed for outdoor use.
              I’ve seen only one map update so far - the one the removed trails from higher zoom levels. Now trails disappear from the map before outlines of buildings, which is what we need for outdoor use.
              • Frederick RochetteF Offline
                Frederick Rochette Bronze Member
                I received my SV2 yesterday and I must say it’s magnificent, especially the screen.
                First night with it and the sleep analysis seems OK.
                As for the optical heart rate monitor, it seems much more reliable and accurate (not to say perfect :-)) for everyday use, as I haven’t had the opportunity to test it while running yet…
                Otherwise, the buttons seem less well adjusted than on the SV1, especially the middle one, which is less firm and moves a little, but maybe that will settle down over time. This gives the impression of a watch that is not as well made as the SV1, which feels really sturdy in comparison.
                I also regret that it is not possible to duplicate the sports modes from the SV1 to the SV2, as well as all the settings.
                v.sacreV OutdoorManO 2 Replies Last reply Reply Quote 1
                • v.sacreV Offline
                  v.sacre Silver Members @Frederick Rochette
                  @Frederick-Rochette Indeed sports mode should be stored in suunto app and transferred from one device to the other.
                  Other point I noticed also is that the vibration of the alarm is a bit less strong than on SV1. But still enough to wake me up.
                  Suunto App: Android Beta
                    Egika Platinum Member @v.sacre
                    @v.sacre said in Suunto Vertical 2 General Discussion:
                    Not sure if this will easily work. Different models (and different firmware versions) have different data available to be used in sport modes. Yes, this could be done with additional checks, warnings or empty fields, etc.
                    Just wanted to say that it is not a no-brainer. And evaluating how many times how many users are affected by this, maybe this feature is not so high on the priority list, as other things…
                    thanasisT 1 Reply Last reply Reply Quote 2
                    • OutdoorManO Online
                      OutdoorMan Bronze Member @Frederick Rochette
                      @Frederick-Rochette That’s how Coros does it. When you get a new watch you can either set it up as a new one, or restore previous settings stored from previous watches. It’s all saved automatically in the app, you don’t have to do anything, just press a button to restore.
                      JosaipluJ 1 Reply Last reply Reply Quote 3
                      • JosaipluJ Offline
                        Josaiplu @OutdoorMan
                        @OutdoorMan garmin also did it this way both allow to easily migrate or restore a watch and it is really convenient even if it is not a feature that you use often
                          Does the Vertical 2 have Custom battery mode?
                          The Race series didn’t have it, only the Vertical, and the Vertical 2 is kind of like a Race on steroids, so I don’t know what it’s like.
                          v.sacreV 1 Reply Last reply Reply Quote 0
                          • v.sacreV Offline
                            It may be interesting as well when doing hard reset in order to restore all user parameters and sports mode !
                            • v.sacreV Offline
                              v.sacre Silver Members @maszop
                              @maszop No custom battery mode
                                maszop Bronze Member @v.sacre
                                @v.sacre It’s a shame. It’s about the touchscreen settings.
                                Without Custom battery mode (or more specifically, touchscreen), you won’t be able to access some features.
                                So, despite the name, the Vertical 2 is a bit of a remake of the Race. Just like the Race S.
                                  Tieutieu Platinum Member @maszop
                                  As long as FW is the same than SR, SR2 and SRs, I wasn’t excepting any change about custom battery modes on SV2, for now.
                                  Maybe new hardware and future FW will someday introduce that (and if so I would likely bet that It will not be possible to access such custom modes on SR and SRs).
                                  • martintrailM Offline
                                    martintrail Silver Members
                                    I am amazed that in my country (CZ), the Suunto Vertical Ti with solar is sold for more money than the new titanium V2. 😄
                                    Vertical Titanium Solar
                                    • JonasLarssonJ Offline
                                      JonasLarsson @v.sacre
                                      @JonasLarsson here you are, SV2 in Titanium Sage version:
                                      Don’t hesitate to ask if you want specific picture
                                      B e a u t i f u l
                                      Suunto Vertical 2
                                        maszop Bronze Member @Tieutieu
                                        @Tieutieu If so, the watch interface also needs to be fixed/changed. You could call this another bug.
                                        Without the touch option during an activity, it’s impossible to change some things on the screen, such as the displayed remaining elevation gain/loss.
                                        EgikaE TieutieuT 2 Replies Last reply Reply Quote 0
                                          Egika Platinum Member @maszop
                                          A bug per definition is something that is not working as designed.
                                          In this case it is working as designed - it just changed (as will every other AMOLED device before). You can like or dislike the change (I understand, you dislike it), but you cannot call it a bug.
                                            @maszop not a bug to me ; all amoled models so far, since they’ve been launched, have no custom battery modes unlike MIps models. It’s a choice (understable when you thing about AOD extra battery consumption and considering that SR and SRs were the first real amoled watches - i put S7 aside).
