    Random Issue
    4 Posts 4 Posters 294 Views 4 Watching
      Tommylee84
      So today I had an issue after a run I went to sync my watch and the app (iPhone 16 Pro iOS 26) said it was busy. I tried to click a button on the watch and nothing happened, I couldn’t unlock the watch via hot key. I held the top key for 12 seconds and it soft rebooted but every time I go to sync it says the watch is busy and I have to press the bottom button to get it to sync, is this normal?
      • Kraisun TuntaK Offline
        Kraisun Tunta
        Android is like that. The watch doesn’t do anything, but it says it’s busy.
        Suunto : S-V, S-R, S9PP, S9BC
          tommieboy @Tommylee84
          @Tommylee84
          I often see the “watch is busy” when syncing but usually within 30 sec it does the sync.
          • R Offline
            Ries22 @Kraisun Tunta
            @Kraisun-Tunta. I’ve the same problem, app thinks watch is in sports mode while it’s not, but I’m using iOS. Have to press lower button on watch to be able to sync. This behaviour happened after the update to 2.46.14
