ZoneSense + Garmin HRM Pro
I’ve had the watch for four weeks now and have already done several runs. Today was my first run where I wanted to test ZoneSense. I’m using the Garmin HRM Pro Premium chest strap and didn’t receive any data during the entire run. Is the strap not suitable for this?
@SyntaxError do you mean HMR Pro Plus? It tracks more data than a standard HRM. I had used Polar watches before this and my HRM Pro Plus couldn’t be used. It is likely the same for Suunto watches.
@SyntaxError however, check this thread: https://forum.suunto.com/topic/11753/zonesense-garmin-hrm-pro/8
@tm3610 said in ZoneSense + Garmin HRM Pro:
Thx, I will give it a try
@SyntaxError you installed ZoneSense+ app, didn’t you?
@Alonz of course and it says “waiting for data”.
I have Garmin HRM Pro (not plus) and it works perfectly with ZoneSense. How exactly did you set your activity? Did you enable the ZS app or just wanted to see data fields or intensity zones?
@Francesco-Pagano the App ist enabled and running.
@SyntaxError I have an HRM-Pro and it works with Zonesense
One thing that comes to my mind: are you sure that the watch doesn’t fallback to OHR? Since the last update (I’ve a Race 1) it happened several times for me that the HRM disconnected right at the beginning. The first two times I didn’t notice (I run by power and only use ZoneSene but no absolute HR-values) but now I know better and pay close attention to it.
On Wednesday it happened 3 times in a row that it disconnected while changing the intensity-gauge from HR to ZoneSense.
At the end I gave up and just kept it at HR and it didn’t disconnect.TL;DR maybe take a glimpse under the watch if the green light is off while running.
@MarkusG I made a rollback to the previous Firmware so it’s not a problem of the latest update.
@SyntaxError HRM is connected to Garmin’s app and therefore blocking HRV transmission to Suunto (HR alone is being transmitted).
You must unpair HRM from your phone, remove it from the GC and after that ZoneSense will start working like a charm
@Belial are you sue, that r-r data isn’t transmitted anymore in that case? I used an HRM DUAL with a Garmin Watch via ANT+ and a Suunto via Bluetooth and ZoneSense worked…
@Belial said in ZoneSense + Garmin HRM Pro:
That sounds plausible. I’ll test that.
@2b2bff I’m sure of one thing - if HRM is connected to the phone and GC app, it doesn’t broadcast R-R. After searching through the internet I’ve found info, that R-R data in Garmin’s HRM is sent only when one BT connection is present. I haven’t tested BT and ANT+ connection simultaneously, but maybe it’s possible to function side-by-side.
ZoneSense with HRM started working without any issues just after I’ve deleted phone’s BT pairing and is working till now.
